IgniTech ignition modules - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 6 (permalink) Old 04-27-2009, 08:18 AM Thread Starter
Arrow IgniTech ignition modules
Firstly, am I right in thinking that there are no aftermarket ignition units for the 900 cruisers?
If not, then can any of the more induction-savvy comment on the TCIP4 from this company?
http://www.ignitech.cz/english/aindex.htm
Will it work with our bikes? Is it an easy swap?
Also, if I buy one of these, I may need to send them a wiring diagram of the connector; does anyone know if the wiring diagram in the Haynes manual is correct? Could I just send a copy of that page?
I know a few of the triple owners use them and also quite a few Ducati Monster owners but I'm curious as to the application in a twin and whether it'll be easy enough to set up.
The reason for my post is that I'm having problems with my bike and I have reason to believe that it's the igniter. I don't wanna pay out for another Gill unit as I believe they're $pendy.
270* is offline
post #2 of 6 (permalink) Old 04-27-2009, 08:56 AM
Motorcyclist
Supernova
Main Motorcycle: 2013 Tiger 800XC
propforward's Avatar
Other Motorcycle: 2007 Bonneville, ST1300
Extra Motorcycle: G12DL, ZX1100, KLX400
I don't know about those, but I understand that pieman can (and has) remapped ignition modules for the cruiser twins. You should contact him via PM and see what he says - his remaps are highly rated.
Before he did it, I'd have said it couldn't be done.
propforward is online now
post #3 of 6 (permalink) Old 04-27-2009, 09:20 AM
Main Motorcycle: Yes
B02S4's Avatar
The OP was talking about an aftermarket replacement unit, not remapping the OEM Gill...
And to my knowledge the OP is correct.
B02S4 is offline
post #4 of 6 (permalink) Old 04-27-2009, 02:33 PM
Motorcyclist
Supernova
So he did. It's an alternative route though.
Although if all he wants is a replacement, then by the time he has found a used OEM one that works the problem is solved, right?
post #5 of 6 (permalink) Old 04-28-2009, 07:49 AM
Main Motorcycle: Scrambler!
reflectedstatic's Avatar
Other Motorcycle: Waterford F-22 (acoustic)
I'll cross the wiring diagram in the Haynes manual against the factory service manual tonight, but I imagine the Haynes manual is right. They probably just need the pin-out of the Gill unit to match everything up and make sure their unit features the necessary inputs and outputs.
That's an interesting idea, and it's dirt cheap compared to a Gill, especially where you are. If you go for it, definitely post up here. User-programmable ignition for about the cost of a remapped box... I like the possibilities.
reflectedstatic is offline
post #6 of 6 (permalink) Old 04-29-2009, 12:39 PM
Haynes and FSM show the same pins going to the same places, so I'm sure you could use the diagram from the Haynes manual. Try to get pics of the ignition circuit pages (16.60 and 16.61) from the FSM to send them though, because it's a lot less cluttered. I'd hook you up, but I'm without a digital camera at the moment.
BC Performance Ignition Modules Goin-Commando Twins Technical Talk 16 08-12-2007 07:48 PM
Tires and ignition modules... Help! dimdaveom Speed Triple Forum 8 03-30-2007 04:42 AM
Problems With ignition Modules? 1200 Daytona scooty27 Daytona Deliberations 10 03-12-2006 07:16 PM
Speed chip modules SLAPSHOT Speed Triple Forum 5 07-01-2005 01:08 AM
Ignition modules WFO750 Maintenance & Workshop Talk 2 03-10-2005 12:06 AM
