This thread is a series of notes to aid in the replacement of clutch springs on the Bonneville. This is a common modification, and is not particularly difficult. As usual it is recommended that you have a service manual to hand for detailed direction, plus it is assumed that you are mechanically competent.
I sure wish I was.
Make sure you have a brand new clutch cover gasket available before attempting the job.
I am replacing the springs because as a result of my airbox removal, and subsequent power increase, coupled with my not insignificant stature, my clutch has started slipping. This manifests itself typically in throttle roll ons in 4th or 5th gear, at around 4000 to 5000 rpm. It also happens if I whack the throttle open
I am using the green Barnett clutch springs, which are well able to handle up to 115 RWHP (as proven by Carlos at TPUSA) so for a fat bloke on an ARKed bike should be just fine. You can get these springs from our various site sponsors.
I changed the oil in my bike about 400 miles ago, and since I am a lover of a certain brand of quite expensive oil that shall not be named here (go find an oil thread if you’re into that) I didn’t really want to dump the oil. So – I took the advice of my good friend Sweatmachine, and leaned the bike way way over on the right side. I did it using an engine hoist that I happen to have. You can do it by carefully covering the bike with shop towels and leaning it up against something – whatever you are comfortable with.
I removed the seat, gas tank and battery for this.
Here is the bike as I am lowering it:
And here it is lowered as far as possible (you can go further if you remove the rear brake lever and the footpeg, but you don't need to):
In this position there is practically no oil loss when removing the clutch cover.
So – begin.
Remove the clutch cable from the engine mount, and remove the gear shift lever.
Then place shop towels / tray under the bike to catch any oil spillage.
Now, go around the bolts holding the clutch cover on, and crack them loose. Go around and remove all the bolts. Make sure you get them all. There are 2 different lengths used, but don’t worry it is quite obvious which ones go where when replacing them.
Now remove the clutch cover. If you are removing the cover for the first time it WILL be difficult to get to budge. Careful taps around the outside with a rubber mallet will dislodge it. Carefully mind you. Once it cracks loose, lift it vertically away from the engine case. Do not lose the 4 dowel pins that locate the clutch cover.
If this is the first time the cover is coming off it WILL tear the gasket. C’est la vie – it’s not worth worrying about. I had the cover off 6 months ago for a different reason, so my gasket came out whole.
Once you have the cover off, you must clean the gasket surfaces on clutch cover and engine case. If there are traces of stuck gasket, these are best removed with a gasket scraper (available from sears and other auto stores). You can also do it with a razor blade – BUT it is very easy to scratch the surface of the metal, which can lead to oil leaks. You must be very careful, and do not scratch, nick or mar the sealing surfaces. Do not leave any traces of old gasket material. It is adviseable to stuff shop towels everywhere before doing this so as to not drop any bits of gasket in the crank cases. Sometimes, when doing the clutch cover for the first time, it can be best to bite the bullet and dump the oil, so that you can have the bike upright, minimizing the chance of getting crap in the engine.
Once your gasket surfaces are clean, you can proceed with spring replacement.
This is what is behind the clutch cover:
The blue arrow points to a short shaft which transfers your clutch lever movement to the clutch plates. It is very easy to pull out with your fingers. Do so, and carefully consider how free it is. This is important later.
The red arrows are 4 bolts that hold the clutch spring retainer and clutch springs in place. You can crack these 4 bolts loose, and evenly undo them to release the clutch spring retainer and springs, and remove them. I made a note of the orientation so that I could put the retainer back the same way.
The yellow arrow is pointing to a wavy washer on the starter gear shaft. DO NOT UNDER ANY CIRCUMSTANCES ASSEMBLE THE MOTOR WITHOUT THIS WAVY WASHER. It may look inconsequential, but it isn’t.
I sure wish I was.
So – begin.
