Bonneville Headlight - Triumph Forum: Triumph Rat Motorcycle Forums
New BonnevilleHonda Powersports Ontario TourismMotorcycle.com
Old 02-15-2009, 12:42 PM   #1 (permalink)
Took my Bonneville in for its MOT yesterday and although it passed, the examiner was not happy about the headlight. In his opinion there is too much movement in it, which could cause problems to vehicles I was following. He tried to alter it but couldnt, I have tried the same this morning. I even checked against another Bonneville I saw parked up and that was the same. The movement is only very small and it seems to me that it is just play in the rubber washers, anyone else had problems with there headlight. The bike is a 05 T100
The Dodger is offline   Reply With Quote
Old 02-15-2009, 12:48 PM   #2 (permalink)
Favourite Bike: Thruxton
Every motorcycle I have ever owned had some movement in the headlight, as does my '07 Bonneville.
davidc is offline   Reply With Quote
Old 02-15-2009, 12:53 PM   #3 (permalink)
My T100 headlamp has a lot of movement too, although it passed the MOT, and it appears to be due to the rubber mounts. Although I don't think you could actually alter the setting of the headlamp it does seem to wobble alot.
I've never noticed this on any other bike I've owned.
39500 is offline   Reply With Quote
Old 02-15-2009, 01:32 PM   #4 (permalink)
Favourite Bike: '09 T-100
It prevents high frequency low amplitude loading of the filament preventing premature light failure. A further benefit is is throws a darting beam which alerts drivers regarding your presence...a good thing.
BTW...what is the best low cost kluge for an upgraded halogen? 65W F7 or F9 with a bit of surgery on the lamp base?
biker7 is offline   Reply With Quote
Old 02-15-2009, 05:41 PM   #5 (permalink)
Favourite Bike: 09 Bonneville T100
Other Motorcycle: 1972 Honda CB450
Had the same problem with my light and it would slowly end up pointing downwards. Rubbers were not gripping the light firmly and the pressure of the wires entering the rear did not help. Had the 800km service done on Friday and mentioned it to be looked at when they fitted the flyscreen. Much better now with very little movement.
Read recently about a HID kit that has been developed to replace the H4 globe. The transformer was about a third smaller and would quite easily fit behind the light shell. Anyone seen the same ? I think it was on the UK eBay website. Would improve lighting greatly as it had a 6000l output.
dingo123 is offline   Reply With Quote
Old 02-15-2009, 07:17 PM   #6 (permalink)
Thumbs up Light
Get a little tube of loctite & put a drop /2 on it. It'll do the trick!
CAPT D
Old 02-22-2009, 11:09 PM   #7 (permalink)
Do you think this is the bulb or filament, or the headlamp bucket? I recently replaced my stock lense/mirror and bulb kit. After installation I've noticed quite a bit of movement compared to the stock parts. It may be I didn't seat the bulb well when I installed it in the base.
2005 Thruxton
2000 Speed Triple
whoa is offline   Reply With Quote
Old 10-16-2011, 01:59 PM   #8 (permalink)
Favourite Bike: Bonneville T100
Other Motorcycle: Vespa ET4
Bonneville Headlight movement with fly screen
I recently fitted a fly screen to my 2011 Bonneville and noticed with the wind hitting the screen at higher speeds my headlight moves upwards. No matter how tight I get it, because of the rubber mounts the headlight has a little play. I noticed that the headlight on the standard bonneville models does not have this problem.
Any suggestions?
Sean
seanst100 is offline   Reply With Quote
Bonneville America Headlight switch cambo72 Twins Technical Talk 2 12-28-2008 10:42 PM
H.I.D headlight on '82 Bonneville triday12 Classic, Vintage & Veteran 1 12-28-2008 07:58 AM
Removing Bonneville Headlight Brackets brownbomber Maintenance & Workshop Talk 3 09-25-2006 03:43 PM
Bonneville and T100 Headlight ohiorider Twins Talk 29 03-23-2006 11:56 AM
Headlight Visor. Bonneville & T100 MotoSayle Twins Talk 2 07-02-2005 04:46 PM
