advantage to changing front pegs? - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismSportbikeTrackGearNew BonnevilleHonda Powersports
Old 02-15-2009, 10:25 AM   #1 (permalink)
dseely1's Avatar
Is there that much difference in comfort if you change your front pegs? Most of the pictures I look at all still have the triumph pegs. What is the advantage of (for example) the kuryakyn dually pegs?
David
Clearview screen, TOR pipes, AI removed, rejetted, light bar, iso grips, kuryakyn mirrors, chromed out, tach, saddleman bags and trunk (permanently attached - throw-over yoke rmoved), corbin saddle, bonneville performance oil pressure gauge, Added two rear light, (tail and brake)..........
dseely1 is offline   Reply With Quote
Old 02-15-2009, 05:26 PM   #2 (permalink)
Favourite Bike: Thruxton
For some, probably most, the change is for appearence - a sleeker look, although a rider may gain a bit more comfort if the new peg is a bit lower than stock. I switched sides with my pegs and got a little over one half inch lower and rearward positioning that I find way more comfortable than the standard set up.
davidc is offline   Reply With Quote
Front Sprocket changing kiwijohn Tiger Workshop (archive) 1 07-04-2008 08:51 AM
Need some help changing the front sprocket on the S3 Gennaro Speed Triple Forum 10 05-03-2008 12:23 AM
front sprocket changing Binnsy Twins Technical Talk 12 03-27-2007 03:30 AM
changing front bulb PtboSprintSt Sprint Forum 3 08-27-2006 05:32 AM
Changing Front Fender on a Bonnie Fed Maintenance & Workshop Talk 3 10-15-2005 02:11 PM
