Velocity Stacks in the Airbox - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsSportbikeTrackGearMotorcycle.comNew Bonneville
Old 02-13-2009, 07:39 PM   #1 (permalink)
Favourite Bike: scram 865 ī07
twinfan's Avatar
hi ventura
your work on this link http://www.triumphrat.net/twins-tech...o-results.html
looks great...if you still want to do any tests try aluminium velocity stacks on the original airbox...just throw out those rubber parts and close the rest with silicone or any rubberplate
because of the step in the stock rubberparts there is no good airflow and it causes interferences...throw out the difference plate between head and intakes and use 70mm long velocity stacks
look...here´s a pic on stock airbox but with fcr´s...scroll down and click on third and fourth pic:
http://www.classicbike-raisch.de/htm..._vergaser.html
you will have to dremel a little bit on the diameter at the box to make them fit...but stock rubberparts will refit so that there are no gaps
there are two versions...50mm for the thrux and bonnie for better reving and torque at high revs...70mm for the scram because of more torque at low revs...i can go get them for you if you don´t find in UK
cheers
twinfan
twinfan is offline   Reply With Quote
Old 02-14-2009, 05:55 AM   #2 (permalink)
Favourite Bike: Can't decide now!!
Ventura's Avatar
Other Motorcycle: Scram + Thrux
Extra Motorcycle: '71 BSA Thunderbolt
Many thanks Twinfan for the info and the link.
What a great website!!
I just wish my understanding of German was better!!
But in the universal language of biking it mostly seems self explanitory.
I think!!?
You have a PM.
V.
2006 Scrambler, VARK'd, 155/40, 790 In-cam, Pieman'd igniter, DNA Pods, Zard 2:1.
2005 Thruxton, Black now, with ARK, FCR 39's & Uni's, Retimed 790 cams, Barnett clutch and suchlike!!
Ventura is offline   Reply With Quote
Old 02-14-2009, 10:12 AM   #3 (permalink)
Favourite Bike: 2007 Bonneville Black
Gob-ny-geay's Avatar
Other Motorcycle: 2008 Suzuki SV650 (track
Extra Motorcycle: 2011 Road King Classic
hi ventura
looks great...if you still want to do any tests try aluminium velocity stacks on the original airbox...just throw out those rubber parts and close the rest with silicone or any rubberpla...
twinfan
Twinfan,
Very nice post. I enjoy this "out of the box" (or is it "in" the box) thinking.
I have done the exact same thing with Velocity Stacks, with excellent SOTP results. Sorry Ventura, no Dyno graph.
my source was www.Velocity-Of-Sound.com USD$29.00 ea. 54mm O.D. X 70mm long. Took ten days delivery, Australia to Illinois.
Slight difference - I fit mine INSIDE the rubber vibration isolators/connectors. The 54mm O.D. velocitystack slides into the rubber piece nice and tight, and yes, you need to "round" out the oval opening in the airbox to fit.
I also cut out the opposite end of the K&N replacement filter, added a 1/4" thick neoprene gasket, and then cut outan opemnong at the opposite end of the stock airbox. That done, it's a dual opening airbox (JohnyC originated this, and also tried the 790 Cam).
The airbox interior, after removing the snorkle and flow divertor, has TONS of plastic shelves, brackets, ribs, etc., that can ALL be removed safely, without compromising the strength, or integrity of the box.
All that done, the results are extremely satisfying. Very good pull from a standing start, and the noticable increased "roar" heard from inside the box tells me "something" is going on".
Total cost? My labor is always free, and the time spent (one full Saturday) was very enjoyable. Other than that, say $10 for dremel tool bits, and $68.00 for the two stack.
I have tons of photos on the airbox interior work, installation of the stacks, and other mods done to the much maligned airbox. Anyone interested just PM me.
Priceless.
More posts and threads like this Twinfan and Ventura, great stuff.
Gob-ny-geay is offline   Reply With Quote
Old 02-14-2009, 12:04 PM   #4 (permalink)
twinfan's Avatar
how did you make it fit inside the stock rubberpart between airbox and carb? i tried it out first (because of 100% stock look) but i didnīt get it
i do like on the link i put in the last post...put some from the inside and a black rubberplate somme mm thick fixed with black silicone from outside to make it tight against water...with the sidepanels on nobody sees
cheers
twinfan
Old 02-14-2009, 01:23 PM   #5 (permalink)
twinfan
I will PM you with photos tomorrow - I'm not at home today, travelling.
It's easy. If you look at the pictures of the Velocity stacks at Velocity-of-Sound.com, you will notice that they have full, radiussed over Bellmouth entries.
This entrance/bellmouth width on the 54mm stacks is just a little too wide, so you need to cut off about 4mm from each side, which isn't much, and still leaves plenty of radius.
Then trim off 10mm from the total length (fine tooth hacksaw and file/sandpaper works great).
Push the stack into the rubber piece, leaving about 20mm exposed. The first "cut-in" square of the airbox inside the opening determines how deep into the box you can go, and acts as a stop. Now although the Stack is a very tight fit in the rubber, it cannot slide forward or back, and is locked in solid. I put a few dabs of RTV Black silicone on just for further safety.
As you noted, the "oval" openings need to be filed out to slightly oversized round with a rat-tail file, which is very easy.
My next move is to design and fabricate much improved "intake" pipes, on both ends,to fit under the sidecovers, but be rigid palstic, not rubber like the snorkle, and non-restrictive to airflow. Thus far, I haven't had any issues with the two ends open, so no hurry. A few others have previously noted airflow problems with the single opening/snorkle removed while riding in severe wind, but it seems like a minority. It may depend on where you live(?).
Some areas are much windier than others, especially flat open plains, etc.
Anyway, I'll send you some digitals tomorrow early AM. Both approaches look like they work fine, obviously you are pleased with yours, just wanted to provide a possible alternate method.
Thanks.
Old 02-14-2009, 06:49 PM   #6 (permalink)
Favourite Bike: '04 Thruxton
agro's Avatar
G'day, have gutted airbox of all the plastic, but use the aussie unifilter replacement element, which has a foam endplate, not solid like the k&n and usa unifilter.
I am interested in your velocity stack mods, could you please post the stack part number that you purchased.
Will PM you for pics re; airbox mods and velocity stack mods..........maybe you can post them for other members?
Cheers..............Agro
"Whale Oil Beef Hooked"
agro is online now   Reply With Quote
Old 02-15-2009, 09:30 AM   #7 (permalink)
Here's a few. Velocity Stack Part # is VS50_70, which refers to the 50mm ID X 70 MM length. Aluminum (or aluminium to you Aussies) is 2mm thick, therefore the ID at the funnel is 54mm, which conveniently fits tightly inside the rubber connector.
I'll send 5 more picks in about 15 minutes, as 5 pics is the limit / post.
Velocity Stacks in the Airbox-triumph-air-cleaner-2009-011.jpg   Velocity Stacks in the Airbox-triumph-air-cleaner-2009-024.jpg   Velocity Stacks in the Airbox-triumph-air-cleaner-2009-017.jpg   Velocity Stacks in the Airbox-triumph-air-cleaner-2009-023.jpg   Velocity Stacks in the Airbox-triumph-air-cleaner-2009-025.jpg
Old 02-15-2009, 09:51 AM   #8 (permalink)
Here's 5 more. In this series, note the amount of "stuff" removed from the interior. If you are familiar with the stock box, you will see how much has been trimmed out.
Hope this inspires others to continue with the trials.
I've got about 50 more pics, so if you need more detail, let me know. Bike runs beautiful. Thanks.
Velocity Stacks in the Airbox-triumph-air-cleaner-2009-018.jpg   Velocity Stacks in the Airbox-triumph-air-cleaner-2009-029.jpg   Velocity Stacks in the Airbox-triumph-air-cleaner-2009-028.jpg   Velocity Stacks in the Airbox-triumph-air-cleaner-2009-019.jpg   Velocity Stacks in the Airbox-triumph-air-cleaner-2009-020.jpg
Old 02-15-2009, 11:39 AM   #9 (permalink)
Just for reference, here are pics of Air Cleaner Housing BEFORE modifications, and lastly, a pic of the ported and polished intake manifold. If you remove this carb to Cylinder head set-up, the rubber isolator, aluminum manifold, and phenolic spacer all have differing I.D.'s, and the aluminum has casting flash, ridges, etc. An hour or so spent with a Dremel cleans all this up nicely. Tip: Reassemble the three components, and screw a hex nut on the original bolt. Now take a Dremel with a flap wheel sander - 220 grit to start, and match all the I'D's while smoothing out the ridges and bumps. Have Fun!
Velocity Stacks in the Airbox-triumph-air-cleaner-047.jpg   Velocity Stacks in the Airbox-triumph-air-cleaner-048.jpg   Velocity Stacks in the Airbox-triumph-air-cleaner-049.jpg   Velocity Stacks in the Airbox-triumph-air-cleaner-050.jpg   Velocity Stacks in the Airbox-triumph-intake-manifold-003.jpg
Old 02-15-2009, 12:12 PM   #10 (permalink)
Favourite Bike: Bonnie Black Special
PieMan's Avatar
If there is any movement with the three components on the bolt, get the right size heatshrink and put some on the bolt to pad it out and to keep the components exactly in place.
Any smoothing after the carbs and before the valves should be 80 grit at most, to keep the petrol from globing and help with atomisation.
Gob, all that dremel work cleaning up the airbox, you've done a great job, but have you noticed any increased air flow?
Mike (UK)
04 Bonnie Black
PieMan is offline   Reply With Quote
Short Velocity Stacks & Unifilters LOOSE - 60mm Open Velocity Stacks WIN robnobrakes Twins Technical Talk 5 01-29-2009 04:59 PM
velocity stacks pz1 Twins Technical Talk 1 10-18-2007 09:12 PM
Recommendations for Velocity Stacks marvinleal Hinckley Classic Triples 4 06-19-2007 11:45 PM
velocity stacks?? blue-thrux Club Cafe' 13 05-06-2007 10:34 AM
DIY Velocity Stacks TBSstunta Hinckley Classic Triples 8 10-28-2006 10:01 PM
