Turn Signal Flasher Relay - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-14-2009, 07:24 PM   #1 (permalink)
Had a warm day and pulled the Triumph out for a ride...woot, no turn signals...the lights just get brighter but don't blink.
The Triumph Dealer wants $62 for a new one and it will take 7-10 days...Is there a replacement from a place like Napa that might cross reference (I'm sure it's the same as some Japanese car or Honda/Kawi etc.)?
Thanks,
Frank
ArmyBonnie is offline   Reply With Quote
Old 02-14-2009, 08:55 PM   #2 (permalink)
Favourite Bike: Bonneville 07, "Bonnie"
koifarm's Avatar
Other Motorcycle: Past rides, 66 bonneville
Extra Motorcycle: Past rides, 72 bonneville
No flashee
Find the turn signal flasher and pull the plug, gently clean the contacts with ultrafine sandpaper and re assemble using dielectric grease to protect the contacts. Your contacts can corrode or get a light coating of oxidation and cause an interrupted voltage surge. The brightening of your lights may be the clue here.
good luck...
Sitting on a cornflake waiting for the van to come!
koifarm is offline   Reply With Quote
Old 02-14-2009, 10:25 PM   #3 (permalink)
Thumbs up Better yet
Buy a signal tender that stops the lights when you dont! It WILL save your lofe some day!!
CAPT D
Old 02-14-2009, 10:36 PM   #4 (permalink)
Favourite Bike: 2005 Bonneville Blue 790
It's definitely a standard part, although I don't know the cross-reference. Someone at some point discovered it was the same as a replacement for a certain Ford product, if I remember correctly.
If drying and cleaning doesn't work, you might be able to cross-reference it based on what's written on it. Pull it out and have a look.
Marty
Old 02-15-2009, 06:27 AM   #5 (permalink)
I'm pulling it out today and going to try and find a replacement...if I do find a standard part, I'll repost with pictures.
Thanks,
Frank
Old 02-15-2009, 10:27 AM   #6 (permalink)
More than likely you'll find it's the same as any other motorcycle flasher relay with the same number of pins.
39500 is offline   Reply With Quote
Old 02-24-2009, 07:18 PM   #7 (permalink)
Forum Liaison
Favourite Bike: 04 Thruxton
RumRunner's Avatar
OK maybe someone here knows the answer to this one:
Just went for a ride everythings been working fine... Now the right turn signal works, but when I turn on the left turn signal all 4 flashers blink??? Any Clues?
RumRunner is offline   Reply With Quote
Old 02-24-2009, 07:47 PM   #8 (permalink)
Favourite Bike: '09 T-100
Quite possibly a diode which direct current in only one direction when working properly. Has the polarity been reversed at some point in your turn signal circuit? Diodes don't like reverse polarity. Most motorcycles have diodes within their turn signal circuit and what divorces 4 way flashers from independent sides of the bike. I will be getting a manual in the next couple of days and maybe able to help when I have a schematic of the circuit.
Best,
George
biker7 is offline   Reply With Quote
Old 02-25-2009, 12:10 AM   #9 (permalink)
Common part
I replaced mine with one I got from Advance auto parts. I don't remember what I used but I think it might come from a Ford Ranger. Take the old one in and they can match it up for you. The one i got had one side longer then the rest but it fit fine. Oh yeah it was about $5.00 as I recall.
You've never rode until you've been throwed.
Anchorbend is offline   Reply With Quote
Old 02-25-2009, 08:24 AM   #10 (permalink)
Quite certain there is nothing wrong with the OP's flasher relay. The relay is the very same module that powers both the turn signals independently as well as the turn signals all together aka 4-way flasher. So his flasher relay is working. The issue is directing current flow. He likely has a blown diode on the one side that is setting all four signals off. Diodes are inexpensive and available at Radio Shack.
George
Turn Signal Flasher Don x 3 Trophy 4 09-20-2008 12:17 PM
Where is the turn signal relay? Mark S. Sprint Forum 5 05-07-2008 05:35 PM
turn signal relay AJF1134 Twins Technical Talk 4 02-05-2008 08:36 PM
turn signal flasher help needed robadele Sprint Forum 4 07-24-2006 08:29 PM
Wet Flasher relay? Turn signal stays on after rain/wash. '04 RS Sprint Forum 4 06-15-2004 01:23 PM
