steering head lock - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Honda PowersportsSportbikeTrackGear
Old 02-14-2009, 06:25 PM   #1 (permalink)
Newbie
Favourite Bike: my 07 bonneville
steering head lock
I recently bought a 2007 Bonnie that was a repo, so I didn't the key for the steering lock. I bought a new lock cylinder from the dealer along with a new rivet. Has anyone had experience changing this lock? I figure I can grind the head off the old rivet holding the swinging cover, but how to get the rest of the rivet out? The new rivet has a kind of stamped split to it so that when you drive it in, the bottom will spread and lock into a relief at the bottom of the rivet hole. Any ideas are welcome
fjd821 is offline   Reply With Quote
Old 02-14-2009, 08:32 PM   #2 (permalink)
Favourite Bike: Bonneville 07, "Bonnie"
koifarm's Avatar
Other Motorcycle: Past rides, 66 bonneville
Extra Motorcycle: Past rides, 72 bonneville
fork lock
Theyr's not much written down about how to disassemble those locks, there is a printout of it at Bike Bandit:
iconhttp://www.bikebandit.com/triumph-mo...-2007/o/m17653
and I'll attempt to download that picture for you here:
so you can see what the whole thing looks like.
there were no specific instructions anywhere I could find so keep looking for someone who has been there to give you the best hints for getting it out.
You may be able to get a key by tracing back the serial numbers of your bike.
If not the easiest solution looks to be like drilling out the rivet with the correct size drill bit, cleaning or blowing out the shavings and reinstalling your new lock.
Sitting on a cornflake waiting for the van to come!
koifarm is offline   Reply With Quote
Old 02-14-2009, 09:15 PM   #3 (permalink)
paulhdick's Avatar
Extra Motorcycle: '09 BMW R1200GS
Had to do it on my scrambler ....
Long story short ... I had to do it on my Scrambler when I first took posession of the bike as the dealer had lost my key (igntion, too) and I got so tired of their lies and mistakes I replaced both myself.
You need to completely remove the rivet holding the cover on first. You can do this with a pair of good pliers. It pulls right out.
Since I did not have the original key to remove the lock with I just used a hardened 1/4 inch drill bit and drilled straight through the center of the key hole until I go past the pins. The lock assembly comes right out after that.
Something I noticed with the lock assembly and probably the main two problems folks have with the steering head locks. One is there was no lubrication at all in the steering lock hole and it was already rusted up a bit as new. Second was the threaded guide pin was not locktighted in place and very loose. If it backs out even a little the lock will be difficult to operate or even jam. I Loctited the screw in place after making sure it fit done the lock hole without binding, then I put a good coating of moly lube on the eniter assembly. Have never had a problem with it since then and I use it all the time. ALthough the arrow is obscured a bit it is pointing to the screw that causes all the problems.
I did not use the rivet that came with my new lock assembly. Instead I tapped the rivet hole and used a small torx security screw in its place.
Raced desert in SoCal during late 60's/early 70's. All my heros were on Triumphs or Huskys. Triumph went in to my subconscious and designed the perfect bike for me. I could not stop myself from buying the Scrambler ...
paulhdick is offline   Reply With Quote
Old 02-14-2009, 10:13 PM   #4 (permalink)
Newbie
Thanks
Paulhdick, that was alot of help. I'll get going on that tomorrow. I haven't registered the bike yet. but i'm anxious to get in my first ride in about 12 yrs.
Old 02-14-2009, 10:20 PM   #5 (permalink)
Lock
Due yourself a favor & return the lock!! Get a disc lock or better! These fork locks become a problem sometime & can cause real trouble!. Dealer when I bought mine new said "Dont use it!" Heard some horror stories about people getting stuck somewhere after breaking the key or whatever. Your choice? I DONT use mine no will I ever try!!
CAPT D
Old 02-15-2009, 07:21 PM   #6 (permalink)
These older 70s type steering locks if I remember rightly can be removed by using a punch, [or even mole grips] or similar behind the rivet [which is hammered in] once you get it to come out a bit, it can be withdrawn quite easily. I dont think filing the head off the rivet is a good idea, unless you can drill the rivet out?. Try method A first, if not sucessful go for method B
2007 T100, Blue & White, Mototwin S/S Reverse Cone Megas, AI removed,T140 back light & Indicators, K&Q seat, quick detach rack, mainstand, D9 Clock bracket.
1961 Matchless G2 250cc,Standard.
Daveski UK is offline   Reply With Quote
Old 02-15-2009, 07:24 PM   #7 (permalink)
I forget to add, a flat screwdriver under the lock cover [tap with a hammer] is the best way to lever the rivet out.
Old 02-16-2009, 09:29 AM   #8 (permalink)
Favourite Bike: '05 Rocket III
I use mine all the time..just keep the lock lubricated and you'll be fine.
"I spent a lot of my money on booze, birds, and fast cars. The rest I just squandered."
-George Best
BigChiefWoody is offline   Reply With Quote
Old 02-16-2009, 10:05 AM   #9 (permalink)
Curse
Is comming when that "flimsy" key breaks off in the lock - locked in the middle of no place!
CAPT D
Old 02-16-2009, 03:35 PM   #10 (permalink)
Favourite Bike: 2006 Scrambler!
bikebits's Avatar
Other Motorcycle: BMW R1200RT
This is the exact same lock assembly that was used by BMW from the 1950's through the 1980's. Keep it well lubricated and you won't have any problems.
If you need to remove the rivet, as mentioned above, get a slot head screwdriver tip under the cover and lever it out that way.
Dave (Scrambler Trans-Labrador Blog here)
bikebits is offline   Reply With Quote
Steering lock tshadow6 Twins Technical Talk 16 07-28-2009 05:08 PM
Steering Lock Key bonza Twins Technical Talk 11 07-13-2008 11:10 PM
Steering head lock nut size? bobbo T3 Sport / Touring Forum 5 06-28-2008 10:26 AM
T3 Steering Head Lock Nut bobbo Maintenance & Workshop Talk 4 06-27-2008 06:02 PM
Steering way: Degrees of steering lock ChuckofTahoe Sprint Forum 9 09-02-2007 10:35 PM
