Clear Silicone Muffler to Header Sealant?.... - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!SportbikeTrackGearHonda Powersports
Old 02-14-2009, 12:53 PM   #1 (permalink)
Favourite Bike: '09 T-100
I am taking my new '09 Bonny apart before I even ride it being true to my motorhead madness...to remove reflectors, adjust the handlebars down...remove seat strap...you guys get the picture.
Close to top of my list is a bafflectomy of course to make it sound like a motorcycle. I likely would have ridden the bike by now but old man Winter is hanging tough for a while longer...will likely be early March when I make my maiden ride.
Removing the silencers, I noticed the factory applied what appears to be clear silicone between header and silencer pipe. Please see pics below.
Is there anything special about this sealant, i.e. does it have a higher melting point than traditional silicone? Is it clear RTV? Anybody know for sure? I want to keep the muffler and header flanges from getting too cozy and don't want any backfiring due to lean post combustion burn.
Thanks,
George
biker7 is offline   Reply With Quote
Old 02-14-2009, 12:58 PM   #2 (permalink)
Favourite Bike: '67 Rickmann Metisse
dkreidel's Avatar
Other Motorcycle: first bike: '64 Yamaha 80
Extra Motorcycle: Wish I'd kept: 69 Trident
Hi George;
I researched this when installing my Togas, and found that Triumphs OEM clear silicone is not the hi-temp, or sensor friendly variety. I have been using Permatex hi-temp gray silcone that is almost invisible if any weeps out during cure. I used clear (non-hi temp) silicone on my Montana based bike and it seems to be fine too.
I'm sure any quality RTV will be okay. By the way, gasoline works well to clean up the OEM silicone residue on the headers before re-installing the mufflers.
Dick
'09 T100 50th Anniversary- Togas, Hagons, PC V
'09 T100 green/white- Togas; PC III
'07 T100 tang/opal- Togas, Hagons, Sun rims (18" rear)
'06 Scrambler blue/white - Arrow 2>1; Sun rims 19" F&R, Maxxis DTR
'68 T120R - original owner
dkreidel is offline   Reply With Quote
Old 02-14-2009, 01:23 PM   #3 (permalink)
Originally Posted by dkreidel View Post
Hi George;
Dick
Thank you Dick for the advice. I believe I have some sensor safe gray RTV around I can use. I forgot about the sensor safe issue btw and glad you mentioned it even though you stated that Triumph doesn't use a sensor safe sealant per se. Perhaps being down stream of combustion there would be no contamination of O2 or Map sensors indigenous to the new EFI bikes.
I love this forum and thanks again,
George
Old 02-14-2009, 03:14 PM   #4 (permalink)
Favourite Bike: 03 T100
mikeinva's Avatar
make sure its high temp to not all of it is
Old 02-14-2009, 03:25 PM   #5 (permalink)
Thanks Mike...will look into it.
George
Old 02-14-2009, 03:33 PM   #6 (permalink)
Favourite Bike: Velocette Clubman
Calliway's Avatar
Other Motorcycle: 2007 Bonnie Black Cafe
Extra Motorcycle: 77 GS400
Doesn't have to be sensor safe, its downstream of the 02 sensors.
I use muffler cement and not silicone. Did them once and they have never leaked. You can't even tell that there is any on there as the cement doesn't fully cure until its warm.
Oh and your next project should be to pull off that black valve cover as it doesn't match the bike as well as my chrome one will - lol.
Bonneville Owners Group, Edmonton AB
Calliway is offline   Reply With Quote
Old 02-14-2009, 04:55 PM   #7 (permalink)
Favourite Bike: 05 T100
The Triumph workshop manual states - "Apply 4cc of clear silicone sealer to each silencer at the joints with the header pipes. Spread the sealer evenly around the joints."
I.e. it does not state it needs to be high temperature silicone. I've used a standard clear silicone sealer from Loctite a number of times without problems - the joint is far enough away from the heat source to not require high temp silicone. In fact, I believe cheap bathroom sealant would be fine if you've got any clear lying around.
Paul.
Herts. UK
PAAS is online now   Reply With Quote
Old 02-14-2009, 05:34 PM   #8 (permalink)
It is on my list. Btw Cal, have you found a gas tank removal DIY in the archives? I see the rear tank connection quite clearly with the seat removed but nosing around the front of the tank, it isn't clear to me how the front of the tank is secured to the frame. Is it tongue in groove interference holding the front of the tank in place? I don't see any fasteners up front.
Thanks,
George
Old 02-14-2009, 05:38 PM   #9 (permalink)
Thank you PAAS. I thought the interface between rear of header pipe and muffler maybe away from combustion enough to live with the std. melting point of generic silicone. What you write reflects Dick's comments. Thanks for the affirmation as I wasn't sure.
George
Old 02-14-2009, 06:03 PM   #10 (permalink)
Favourite Bike: 04 Bonnie black
[QUOTE=biker7;1201259 the front of the tank is secured to the frame. Is it tongue in groove interference holding the front of the tank in place? I don't see any fasteners up front.
Thanks,
George[/QUOTE]
There are 2 little mounts under the tank that capture rubber covered studs on the frame.Make sure you get the studs into the mounts and not riding on top of them. Tank will still be secure but look too high in front.
rodburner is online now   Reply With Quote
Clear Alternative Clear Lens Ordered for '08 ST-Installation Help? vraptor65 Sprint Forum 28 06-09-2009 09:04 AM
RS Clear Tail Light (Clear Alternatives) Xterrable Sprint Forum 5 10-23-2008 06:12 PM
Can a muffler shop "unbend" the tail end of the header pipes? JG Club Cafe' 4 06-24-2006 08:43 AM
Temp at header/muffler junction? dazco Twins Talk 7 12-20-2005 12:43 PM
Header pipe/Silencer sealant question franco Twins Talk 3 07-16-2005 10:18 PM
