Jetting for Emgo Reverse Cones - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 02-13-2009, 01:12 PM   #1 (permalink)
Favourite Bike: '05 Triumph Bonneville
Craigore's Avatar
Other Motorcycle: '51 Harley Panhead
Extra Motorcycle: '79 Harley Ironhead
I just fit the reverse cone mufflers to my 04 Bonneville that has no airbox mods (yet) besides snorkel pulled.
I have a pair of 115 main jets, will these suffice? I am putting in an order to NB at the moment for some other stuff so figured I'd ask!
Craigore is offline   Reply With Quote
Old 02-13-2009, 01:54 PM   #2 (permalink)
Favourite Bike: 2004 Thruxton
Other Motorcycle: 1971 BMW R50/5
Extra Motorcycle: 1971 CB350
I know the guys with TORs run 118 or 120s with the stock airbox...probably wouldn't kill you to leave it be and see if you get popping on overrun. If you can't eliminate the popping by going out a turn on the pilot screws, then get bigger jets.
Either way, get an AI elimination kit while you're ordering if you haven't already...
--Rich
beemerrich is offline   Reply With Quote
Old 02-13-2009, 10:31 PM   #3 (permalink)
Favourite Bike: '03 T-100 & '08Tiger1050
I would recommend at least 120 main jets. Popping on decel overrun is controlled by your pilot screw adjustments--I would recommend you try about 2.5 turns out on the pilot screws. I believe some '04's still had the pilot screws covered with a small aluminum looking plug with a tiny hole in the center. If yours is this way (take a good mirror and look at the underside of the right carb--look at the front of the carb right next to where the heater wires connect. The pilot screw is beside the carb heater wire connections and to the outside of these connections. If yours has the plug you will see what I described above--it is about half the size of a dime. If yours doesn't have this, but you can see a screw with a slot in the screw, then it has been removed. If you see a screw with a "D" shape depression in the head, then you have the later model that takes a "D" tool for adjusting the pilot screws.
If yours has the plug that I described above, take a 1/8 drill bit and drill the hole in the center larger--this can be done by hand. If you have trouble doing this wrap some tape around the drill bit to make it larger where you are holding it. Once you have the larger hole in the plug, use a long "grabber" type screw and screw it into the plug a shot distance, and try to work the plug out with some pliers on the screw. If you are not in a hurry, cut a 1/2 to 3/4 inch piece off a 1/2 inch rod and drill a hole in the center of this that will clear the grabber screw threads but not the head of the screw. Put this on the grabber screw before you put it into the plug, and use the "hammer" you just made out of the short piece of 1/2" rod to hammer the plug out "slide-hammer" style.
To adjust the pilot screws (mixture screws to some), screw them all the way in (lightly) and then screw them out counting the number of turns.
Larry
Old 03-28-2009, 05:07 PM   #4 (permalink)
Craigore's Avatar
So, I put these on today. What a pain in the A$$! Emgo supplied some exhaust shims which barely work with the adapters. Used half a tube of hi-temp sealant, hopefully it'll keep it from leaking. Changed to 120 jets, will let you know how everything turns out.
Honestly if this doesn't pan out I'm ditching the emgos and going with some Preds or something.
Old 03-28-2009, 05:23 PM   #5 (permalink)
I've had Emgo reverse cones for close to a year now. Chrome is still nice and shiny and they were a perfect fit when mounting. I got mine from Specialty Spares and he supplies a nice adapter to make 'em fit. I am at 6200 feet and I am running 122's. Air box has no snorkel. I started at 130's and have gotten tighter and tighter on the jets. I think 122's work well at my altitude, so I'd go maybe one step up for, at least, for Buffalo.
30942 is offline   Reply With Quote
Old 03-28-2009, 05:25 PM   #6 (permalink)
Craigore's Avatar
Thanks for the advice. I'll ride and check the plugs soon. Sealant is "curing"... know I should leave it be for a while but am too anxious.
Side stand is hitting the muffler. Hm...
Old 03-28-2009, 09:09 PM   #7 (permalink)
Question Emgos
Just did the kit from Bella. It came w/ 130's. So far- so good. Gave a nice little boost @ top rpm! Will see how they work in the long run?
CAPT D
Old 03-28-2009, 11:11 PM   #8 (permalink)
Side-stand cure: Cut a piece of thick leather...about an inch square. Use some of your left over elephant snot--I assume you have a little dab left. Stick the leather to the frame side of the inside of the elbow joint formed by the side-stand and frame. My piece of leather has been in place for 22000 miles now.
Larry
Old 03-29-2009, 12:16 AM   #9 (permalink)
Craigore's Avatar
Sounds killer and completes the look of my bike (FEK, NH rearsets and m-bars)
I have an exhaust leak on the right side. Too bad I threw out the rest of the tube of sealant. It'll have to be until I go to NAPA again. 120s seem to work really well.
I've emailed Specialty Spares about their adapters as I've heard that they're an easy fit. Something about the stupid shims and all that sealant just doesn't sit right, even clamped down the can did move (while sealant was still "wet") around on the adapter a bit :-(
Guessing at some point I'll have to change the wrap on the baffles, can't imagine them holding up to being pounded back into the muffler.
Suggestions?
Old 03-29-2009, 10:48 AM   #10 (permalink)
Thumbs up Emgos
I havent seen 1 set that sealed perfect yet! Pounding baffles?? Why? I dont think the Emgos will like that too much!!!! Anyhow- I love mine! The sound & the look. My stockers even leaked a small bit- no big deal! They seal up tighter when they heat up.
CAPT D
Emgo reverse cones elsabella Hinckley Classic Triples 21 06-17-2010 02:35 AM
Emgo Reverse Cones jcline8 Twins Technical Talk 6 04-10-2008 01:10 PM
I just installed Emgo reverse cones montpablo Twins Technical Talk 16 03-23-2008 02:12 AM
Emgo reverse cones vs. TORs Jedhook28 Twins Technical Talk 4 06-07-2007 01:10 AM
