Air Box Insides - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Ontario TourismMotorcycle.comSportbikeTrackGearHonda Powersports
Old 01-11-2009, 11:02 PM   #1 (permalink)
Favourite Bike: Velocette Clubman
Calliway's Avatar
Other Motorcycle: 2007 Bonnie Black Cafe
Extra Motorcycle: 77 GS400
Air Box Insides
I took off my air box tonight to put in my Bella Corse ARK.
I found that I didn't have to hack it apart or even remove the rear tire. I just undid all the bolts then removed the left hand side panel. I slid out the left panel then lifted the rear end by the frame and slid out the rest of the air box. Fender off, shocks off and left hand can off.
So we talk about how restrictive the box is and since I had it apart I took some pics to post.
The inside with left hand panel off and air filter out:
The oval that feeds both carbs. All the air has to go through this tiny oval after going through the filter:
Bonneville Owners Group, Edmonton AB
Calliway is online now   Reply With Quote
Old 01-11-2009, 11:15 PM   #2 (permalink)
Favourite Bike: '67 Rickmann Metisse
dkreidel's Avatar
Other Motorcycle: first bike: '64 Yamaha 80
Extra Motorcycle: Wish I'd kept: 69 Trident
The air that passes through the baffle only has supply one carburetor at a time. I think the area of the baffle "slot" is about 20-25% greater than the area across the venturi of one carburetor. This is not really an accurate comparision, as there are flow (delta P) losses across the "slot" and through the venturi. One doesn't necessarily want laminar flow through an intake; often a flow bench that measures cfm at a given valve lift can be in improved by inducing turbulent flow. There is no doubt the flow through our airbox is turbulent, but it starts to calm down through the intake rubbers. CV carbs don't like turbulent flow; direct operating carbs (flat slides or round slides) aren't bothered too much by turbulent , non-laminar flow.
Dick
'09 T100 50th Anniversary- Togas, Hagons, PC V
'09 T100 green/white- Togas; PC III
'07 T100 tang/opal- Togas, Hagons, Sun rims (18" rear)
'06 Scrambler blue/white - Arrow 2>1; Sun rims 19" F&R, Maxxis DTR
'68 T120R - original owner
dkreidel is offline   Reply With Quote
Old 01-13-2009, 06:43 AM   #3 (permalink)
Favourite Bike: 2005 T100
Sal Paradise's Avatar
Other Motorcycle: 1974 Yamaha YZ
Yes, but the air pressure must go down on the inside of that plate as you reach high rpms, don't you think?
Kind of like running an extra 5000 feet above your current altitude.
Drunk on the wind in my mouth,
Wringing the handlebar for speed,
Wild to be wreckage forever.
Sal Paradise is offline   Reply With Quote
Old 01-13-2009, 07:19 AM   #4 (permalink)
dkreidel's Avatar
Yes, there are definitley some flow losses. By meauring manifold pressure and seeing how close we are to ~~1092 mm Hg (29.92" hg) at WOT we can really measure how efficient the many intake alternatives really are. It may be very restrictive, or maybe not. If it is indeed like adding 5,000' of altitude the MP will read something like 21 or 22" of MP. The manifold pressure gage doesn't have favorites :>)
Dick
Old 01-13-2009, 08:51 AM   #5 (permalink)
I don't know what the pressure difference would be, but it would be significant. Probably not equivalent of 5000' of elevation. I just made that up.
But that is the reason you need different size jets, isn't it? As you increase the pressure or (decrease the vacum), it pulls less fuel out into the carb and so you increase the jet size.
Old 01-13-2009, 09:00 AM   #6 (permalink)
Favourite Bike: 08 efi bonnie black
Other Motorcycle: none
Extra Motorcycle: none
Smile air box removal
hi does anyone no if there is any difference in performance by removal of the airbox on a efi bonnie
tribon865 is offline   Reply With Quote
Old 01-13-2009, 10:14 AM   #7 (permalink)
Loose Head Administrator
Supernova
propforward's Avatar
British customs did it, and got a significant improvement. A remap of the efi is required. Check this dyno chart:
http://www.triumphrat.net/twins-tech...ml#post1149525
They changed pipes as well as removing the airbox.
Rule 1: Cardio
Rustic Road Progress
Old 01-13-2009, 01:40 PM   #8 (permalink)
Favourite Bike: 03 T100
mikeinva's Avatar
The baffle may limit flow but ,I think what hurts flow the most is all the turns the air must go through to go in and out of the box.If you have ever done any flow bench work you know how bad sharp turns kill flow.Little things can mean alot.The 4 valve heads on these bikes want all the air they can get.The better the head flows the more air it takes to make more power.I ran into something on my motor awhile back that blew my mind.When my motor was stock and i put the 42mm carbs on it ,I had the K&N pod filters that came with the air box kit I had on the bike before I put the big carbs on .It ran fine and was easy to get the jets right.When i built the 898 motor with the big valve flowed head on it.It drove me crazy for awhile ,It would go blood rich over 6500 rpm ,If i put smaller jets in it ,it would get so lean at low rpms it didnt want to take off.Later I found the filters I had on it would not flow as much as the rest of the motor would.I changed to a uni all foam filter and the bike picked up like crazy ,jetting worked like it should again.If the type of pod filter can make that much power what do you think the air box could cost you?
I do agree vac slide carbs do some strange things but i never had any trouble getting them right with out the box.I think the problem is that the stock carbs barley work as they should if everything is right no mater what filters you run.
mikeinva is online now   Reply With Quote
Old 01-13-2009, 01:56 PM   #9 (permalink)
Favourite Bike: KTM 990 Adventure
Other Motorcycle: Thruxton
Extra Motorcycle: KTM EXC 300
Hello
It's good to see another EFI question as I have a 2008 EFI Thrux and have been reading page after page of carb tuning/airbox info. Does anybody know what was used to remap the EFI Bonnie . Power comander or a tune thingy ( name escapes me ). Any body know the cost ,as 15 Hp looks quite a power gain .
Howl is offline   Reply With Quote
Old 01-13-2009, 02:01 PM   #10 (permalink)
Supernova
As I understand the British Customs map can be uploaded to the bike using a tuneboy - I am not at all familiar with how that is done, though from what I have heard it is a simple enough procedure, a bit like transferring a file on a computer. I think Calliway did quite a bit of that kind of thing on his sprint.
Rule 1: Cardio
