One solution that works...
I went with the same solution as Metasac. A quality lens, reflector and lamp made a lot of difference over the lower quality OEM unit. It was also reasonable cost at $70-$80. Owing the amount of fog in and around SF, I also went with a yellow lamp shroud which makes me more visible on the road.
2004 Thrux, FCR39's, Uni filter, 813 cams, Works shocks, Ricor valves, progressive springs, Pieman ignitor, green springs, GT501s, Beringer caliper, predators, damper, fork brace, Corbin gunfighter, custom tinware, lowered instruments, JMC swingarm
