» Links |
01-11-2009
Replacing HandleBar Grips
Can anyone tell me the easiest way to remove my stock handlebar grips on Speedmaster and how to put on new ones. I would like to put the vintage grips on. Do I need a special glue. I heard hairspray works good.
SuperStock Favourite Bike: 06 Sprint ST 1050
Posts: 246 Other Motorcycle: 05 Thruxton 900 Extra Motorcycle: 81 XS650H
compressed air works
a bit of soap and water then air shot near the edge of the rubber will lift it enough to be removed. Same with back on.
Eric
"You're going too fast young man. Me? fast? I only look fast."
01-11-2009
SuperSport Favourite Bike: 1965 TR6SR
Posts: 1,070 Other Motorcycle: 2007 Scrambler Extra Motorcycle: 1978 T140E
Just a little refinement on what cocoselect said. I work a small screwdriver between the grip and bar. Then I lift it and shoot in some windex. If you work the screwdriver around it works the soap around too. Be careful not to puncture the grip. If it's stubborn, I have shot some compressed air. Once again, lifting that screwdriver helps get the air in as well.
I use artist spray adhesive. Be sure to clean the soap out of the inside of the grip if you would reuse them at any point.
Of course, if you're never going to use the grips again, you can just cut them off. Wouldn't recommend that though.
01-12-2009
Supersport 600 Favourite Bike: 2008 t100
Contact cleaner and compressed air works great to remove grips as well
2008 T100 B/W, centerstand, Flanders narrow cafe bars, Manic Salamander barend weights, Sargent Seat, Works Performance Shocks, RaceTech Fork Springs and Emulators, A I removed, desnorkled, Dominator Touring exhaust, 118 mains, no shim, 2 3/4 turns
01-12-2009
SuperStock Favourite Bike: 06 Bonnie T100
Posts: 254 Other Motorcycle: I only got one...
just did this on my bonnie -- i used WD40 to get the suckers off, and a whole lot of grunting and swearing to get them back on. i tried hairspray, but found it not very helpful -- the size of the grips keeps them in place, no problem.
removing the grips is a really easy thing to do. go for it!
nick
"Each day is a journey, and the journey itself home."
-- Matsuo Basho
06 Bonneville T100 (AI removed, snorkel IN, DualStar hotgrips, stock otherwise)
01-12-2009
How do you get the WD4 underneath the grip.
01-12-2009
SuperStock Favourite Bike: Bonneville Black
Posts: 297 Other Motorcycle: Lemond Zurich
Hairspray
I've always used hairspray on my bikes.
You can use the same trick as with the wd40, but you don't have to make sure you get them really clean when you're done. It's slippery when wet and sticky when dry......
08 Bonnie...better on a Black...NH Peashooters...NewBonneville Low cafe bars...Napolean Barends...DeSnorked, Restrictor gone, 125 jets
You can take the boy out of Texas, but you can't take Texas out of the boy.
01-13-2009
just take something slim and long, like a small flathead screwdriver or a chopstick and wedge it under the grip. the rubber will flex upwards and not be damaged, then just squirt some WD40 or hairspray in there and give it a tug. should come right off.
oh -- the throttle side is a little harder since the rubber sits on the plastic throttle assembly, but it should work just the same. maybe be a little more gentle with the throttle side so you don't damage the plastic underneath.
cheers.
nick
-- Matsuo Basho
01-13-2009
250 Grand Prix Favourite Bike: 2002 Bonneville 790
Posts: 132 Other Motorcycle: 06 HD Heritage Softail Extra Motorcycle: 1981 BMW R100RT NEEDS TL
try carb cleaner
Yep, a shot of carb cleaner ( careful of painted surfaces) between the grip and the bar and it will slide right off. Insert a screw driver to lift the edge, spray a few areas , and slide it off. Same with installation. A shot of carb cleaner ,slide it on and it sticks like glue.
01-14-2009
Site Supporter Team Owner Favourite Bike: Velocette Clubman
Posts: 5,103 Other Motorcycle: 2007 Bonnie Black Cafe Extra Motorcycle: 2002 Speed Triple
Very timely thread for me as I am about to do the same when my New Bonnie Black Clubmans get here......
I am trying to understand the throttle grip...... and I have no idea about it since I have never taken it apart. What is the grip actually on since it rotates freely? Can I just slide the whole throttle assembly and grip off the end if I loosen it from the bars and take off the bar end?
