Sticky Throttle Return - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismMotorcycle.comMotorcycle.com Classifieds!Honda Powersports
Old 01-10-2009, 09:35 PM   #1 (permalink)
Favourite Bike: '09 Mystery Black EFI
teachnsurf's Avatar
Outside of loose cables, what else can hinder throttle return.
I fiddle with adjusters and cables seem to be tight, but something is hindering throttle return.
Any ideas?
Thanks.
This is my Bonneville. There are many like it, but this one is mine. My Bonneville is my best friend. It is my life. I must master it as I must master my life. My Bonneville, without me, is useless. Without my Bonneville, I am useless.
teachnsurf is offline   Reply With Quote
Old 01-10-2009, 09:56 PM   #2 (permalink)
Favourite Bike: '03 T-100 & '08Tiger1050
Some have found the throttle assy touching the housing after doing something with the grips, etc. I see you have a 2009. If you haven't been doing anything in the way of changes to the handlebars, etc, that could cause problems, I would suggest taking it back to the dealer. The throttle slack is more touchy on the EFI models, so I would let the dealer set it up correctly, if it were mine.
Larry
Old 01-10-2009, 10:15 PM   #3 (permalink)
Favourite Bike: Bonnie Black Special
PieMan's Avatar
Also make sure the twistgrip rubber isn't binding on the end cap.
Mike (UK)
04 Bonnie Black
PieMan is online now   Reply With Quote
Old 01-11-2009, 02:53 PM   #4 (permalink)
teachnsurf's Avatar
Problem Solved
Not too sure how it happened, but I checked on the bike this morning, and the throttle no longer sticks.
Awesome...a self-healing bonnie.
Old 01-11-2009, 05:03 PM   #5 (permalink)
End Cap
When it sticks again do check the end cap as PieMan said.
I just stumbled upon the fix.
Mine stuck in the afternoon last summer but would work fine in the morning. Heat expansion was probably the issue. You can only back off the end cap so much. I took some fine grit sand paper and took a little off of the throttle grip. A file would work fine also.
The dealer didn't have a clue what to do.
why2
why II is offline   Reply With Quote
Old 01-11-2009, 05:15 PM   #6 (permalink)
Retro-Racer's Avatar
Cheap Chinese made generic dimpled Harley handlebars that are out-of-round is a likely culprit.
/Mike
Retro-Racer is offline   Reply With Quote
Old 01-11-2009, 11:02 PM   #7 (permalink)
Easy Mike.....they're gonna own our country soon.
Larry
Old 01-12-2009, 12:43 AM   #8 (permalink)
Favourite Bike: 2008 Bonnie T100
bonza's Avatar
ditto. this is what happened to mine some months ago
2008 Black and White T100.
AI removed, Bafflectomy, 40/115/1 shim 2.75 turns, Pingel fuel valve, Monza petrol cap, Avon Roadriders, Triumph fabric saddle bags sometimes
I like a man who grins when he fights -
Winston Churchill
bonza is offline   Reply With Quote
Old 01-12-2009, 11:47 AM   #9 (permalink)
Favourite Bike: 05 T100
If you do find the binding is caused by the grip rubbing on the bar end cap, don't take sand paper or a file to it. All you need to do is slightly loosen the two screws that clamp the throttle and brake reservoir to the bars and move the whole assembly slightly away from the bar end so it no longer fouls. Re-tighten the screws (obviously) and you're done.
Paul.
Herts. UK
Old 01-12-2009, 12:02 PM   #10 (permalink)
I'll take that approach next summer.
sticky throttle deanooo311 Twins Technical Talk 1 11-08-2008 05:12 PM
Throttle wont return... HELP VrnJames Twins Technical Talk 9 06-07-2007 09:02 AM
Throttle return Ottmundr Daytona Deliberations 1 05-24-2007 09:24 AM
throttle return spring, hard suspension jbirdfl Sprint Forum 10 08-26-2006 10:44 PM
Sticky Throttle Panthers_Den Sprint Forum 11 10-24-2005 07:53 PM
