Haven't seen anyone do this this to a higher $$ system, but is is very common for modifying the stock mufflers. I recently did it to my stockers with good results. The stock baffle on mine was basically a 2" stub pipe thru a steel disc(the baffle) that had two small, maybe 1/4" holes in it. I drilled three 1/2" holes into it to open it up. I like the results, alot.
It might be easier to experiment by drilling a hole into the end or cutting the end off versus the sides as this might be easier to weld/repair if it didn't work out like you wanted.
Sound after rejet? I don't know as mine is still stock.
2008 Bonneville Black: FNG rider, bafflectomized and drilled, Dart fly screen(blacked out), Napoleon's, Triumph high sissy bar(when the wife is on), Continental Trail Attacks, 140 rear, ride the crap out of it.
