For the record, Triumph's own shop manual gives the final drive gearing on an 865cc Speedy as 16/43 (with a 112 link chain). Bear in mind that the Speedy has a 15" rear wheel when comparing the gearing with Bonnies, Thruxtons and Scramblers, which have 17" rears, so the sprocket sizes would need to be different to achieve the same effective gearing. You can go from an 18T to 19T on a Bonnie without needing a longer chain, so I suspect you could go up to 17T on your Speedy if you wanted to. It doesn't cost much to give it a go to see if you like it (or not).
Paul.
Herts. UK
