Carb Tuning
Keith,
If you do not need jettng,and are just looking for syncronization, you ought to pick up a TwinMax. They're only about $80.00, and they are quite simple to use.
Everything is right there in front of you. Just pull a hose, hook it up,and it's pretty easy from there.
The Hines manual displays it pretty nicely. It's easy with the TwinMax, and you'll probably get a better job than if you took it into the shop.
I use it on my oilhead Beemer, and it works great. I have to pull all the plastic fairing parts off the Beemer first. That's four tmes the work of syncronizing the throttle bodies. My Bonnie is due, and I will be doing it shortly. Believe me, it's a piece of cake...
Cheers...
Life is like a jar of jalapenos.
Be careful what you take pleasure in today,for it my burn your ass tomorrow...
