I just polished out my aluminum clutch cover due to a little off-road scuffing. I used a fine sand sponge and matched the original brush look, really the only option for the clear is to have it clear powdercoated, I had an estimate of around $60, you will have to take out all three bearings for the baking process and these seem to be pressed in so I tried auto type clear high temp in a can and it looks pretty good but when you start to tighten bolts the clear will crack.
As far as the stripping goes I used ace hardware paint stripper in a spray can, most of the original clear came off with just a hosing then the rest with another coat, that original coating comes off super easy with stripper.
I plan on going with the chrome over the winter so the fix will work for now.
2006 Scrambler, Previously had 2004 Bonnie Black, 1995 T-Bird, 1974 Trident, various street and dirt bikes.
