Originally Posted by Pokeyjoe
Ha. No. The Scrambler has the 270° engine and the rest of the Bonnies have 360° engines. Same basic engine with a different crank that moves the torque curve down low at the sacrifice of high RPM horsepower.
Ah, thanks. Missed that bit. Thanks for the correction.
Anyone know of a dyno chart comparing the Scrambler engine to the Bonnie/Thruxton? All I could find online were ones showing the benefits of mods to the Scrambler, but not overlaying a comparison of the two stock bikes.
The difference in the fork rake and a thicker seat make up the 2" difference.
Really? I'm not doubting you, but it seems surprising that a 0.2 degree difference in rake can make that big of a difference. Maybe most of it is in the seat?
I have found many articles online that make reference to a longer suspension, but I can't find any specs to back it up. All the places that list specs either have the same travel listed for each bike (a la the aforementioned Hermys) or say "N/A" next to it. I can't find any place that lists ground clearance.
The reason I am asking is that I would like to get a Bonneville for my travel bike, but it's just too cramped and low. If I knew the Scrambler had longer shocks, I would consider replacing the Bonnie ones with the Scrambler's if it gives an extra inch. I would prefer not have the high pipes, as I would like to mount panniers on it (already own the panniers, just need racks to fit the Bonnie and have a lead on that).
A higher seat would help with the cramped part. I would probably get a custom seat that would add at least two inches. But, I would also like to drop the pegs an inch or so.
Does anyone know of a footpeg-relocation kit for the new Bonnie?
