+1 on the tail bag. It seems that when I used soft saddlebags the handling was not good so I stack my packs behind me. If you want to use saddlebags you can buy the Triumph number plates and you can rest your bags on those, I fabricated a 1" wide piece of aluminum and used 1" spacers and attached it over the heatshields for a rest, on the left side I bent a 1" piece of alum and attached it under the seat then hand bent it over the frame and into an arc to catch the back of the saddlebag, drill it to match the fender bolts and that can act as a rest on that side. The alum was 1"x1/8" and you can hand bend it to fit, lightly sanded they actually looked pretty good, and don't really stand out.
2006 Scrambler, Previously had 2004 Bonnie Black, 1995 T-Bird, 1974 Trident, various street and dirt bikes.
