Old 05-04-2008   #1 (permalink)
Favorite Bike: Triumph Scrambler
Canucks_Fan's Avatar
Other Motorcycle: YZ 250
aluminum scratch removal- any ideas?
My aluminum isn't scratched, but the laquer or whatever they use to coat the engine with is starting to look like crap (from riding through scrub) and it's starting to like like I put the bike down. Does anyone know what they use at the factory to coat the engine with? Or if not what the factory uses, has anyone else come up with an alternative solution?
2006 Triumph Scrambler
2008 Triumph Tiger
2008 Kymco Grandvista
2004 Yamaha YZ250
Canucks_Fan is offline   Reply With Quote
Old 05-04-2008   #2 (permalink)
Favorite Bike: 1970 Triumph TR6R
McBike's Avatar
Other Motorcycle: 2007 T100
Extra Motorcycle: 1969 Bonnie Basket
Back in the day we used a product called semichrome (excuse the spelling) on aluminum. I had my cases on my TR6 looking so good that people thought that they were chromed. A lot of work though.
Mike
The older I get, the faster I went.
McBike is offline   Reply With Quote
Old 05-04-2008   #3 (permalink)
Leeroy's Avatar
My guess is they use a high heat clear paint. I've used it on valve covers I've brush polished to hold the finish, and retard oxidation, several paint manufacturers make it.
Leeroy is offline   Reply With Quote
Old 05-04-2008   #4 (permalink)
Favorite Bike: 2005 Triumph Thruxton
BlueThrux's Avatar
Other Motorcycle: Hopefully a Street Triple
It might be a good time to get the Chrome ones Personally I like the stock brushed look. You may be able to have them wet sanded and then re-cleared useing a high temp clear.
Elwood Blues: We've got a full tank of gas, half a pack of cigarettes, its dark and we are wearing sunglasses.
Jake Blues: Hit it.
BlueThrux is offline   Reply With Quote
Old 05-04-2008   #5 (permalink)
Senior Member - Site Sponsor
JCMoTo's Avatar
Polishing paste and stuff do very little for Alum with coatings or clear laq.
It may even be a clear anodized piece.
A couple of choices to make it nice again.
A bit of work intensive and can cost a few dollars.
Have the coating polished out and have it recoated or anodized
Have the piece dipped/stripped (lye bath) and have it anodized clear.
With a polishing wheel you can do much of the stripping/polishing yourself.
If the piece is clear aluminum there is a product called "Bom's Away"
Workd very nicely.
JC
JCMoTo is offline   Reply With Quote
Old 05-04-2008   #6 (permalink)
Favorite Bike: 2007 Bonnie
mjshaul's Avatar
Other Motorcycle: 1969 Tiger TR6C
Extra Motorcycle: 2006 Ural with Sidecar
My brushed aluminum engine covers were scratched up pretty good (lacquer messed up, etc.) after a low-speed spill on a dirt/gravel road. I removed the lacquer using paint stripper (used gel kind and just brushed it on carefully, protecting surrounding parts of bike with tape), then wet sanded with 300, then 400, 600, 1000, 1500, 2000. Then spread some Blue Magic polish on it with my finger, used a firm cloth buffer on my hand drill, then again with a soft cotton buffer on hand drill, and the thing looks GREAT -- kind of makes other parts look shabby in comparison. There are some other posts on this board that helped me do the above -- lots of elbow grease, but I was really pleased with result.
I did all this with the engine covers still on the bike -- saves a lot of work and doable if you go carefully.
mjshaul is offline   Reply With Quote
Old 05-04-2008   #7 (permalink)
+1 on All of the above
All of which take a lot of elbo grease to put it mildly!! @ least it isnt the normal metal corrosion!! Must not be close to salt air?? Thats a PIA!!
CAPT D
Old 05-05-2008   #8 (permalink)
Lightly sanded and sprayed on some VHT HI-Temp clear paint. Looks like a pretty close match to the factory stuff. I took it out for about an hour today, so it got nice and hot- no discoloration from the paint at all.
http://www.powersportsuperstore.com/...534&click=8322
10 minutes labor and $9.59 total cost = much better looking engine case.
2008 Triumph Tiger
2004 Yamaha YZ250
Aargh!! A Scratch! CommandoRdster Twins Technical Talk 10 03-26-2008 12:59 PM
scratch removal for chrome? dazco Modifications & Workshop Talk 6 07-11-2007 03:46 AM
Oh No !!! A Scratch on my Tank DrMath Twins Talk 18 11-12-2005 05:14 PM
scratch top of panniers while getting on n off malc Tiger Mods & Bolt-Ons 18 10-30-2005 05:25 PM
first scratch... Whisperinsmith Sprint Forum 12 10-05-2005 07:41 AM
