Old 04-30-2008   #1 (permalink)
Favorite Bike: Triumph Bonneville T-100
TwoChordTom's Avatar
Unhappy Screeching Noise coming from the front end
Have a 2006 Bonneville with less than 1,800 miles on it.
The last two mornings, I have noticed a terrible screeching sound which sounds like it's coming out of the front end.
When I did a serach, something came up on speedo cables that can cause this.
Anyone out there have this happen to their bikes?
Took it to the shop and everything looked OK. This only happens for a short time and only once or twice during the past two days.
Thanks.
2006 Bonneville T-100 - B.C. Predator pipes, B.C. ais removal kit, Clearview Small Summer Screen, Sixty8 side panels and cam covers, Triumph locking gas cap, optional seats (not shown), skid pad, chrome shift cover, Triumph Engine Dresser Bars
TwoChordTom is offline   Reply With Quote
Old 04-30-2008   #2 (permalink)
Moderator
Favorite Bike: 2006 Bonneville Black
saphena's Avatar
Other Motorcycle: Huoniao HN125-8
If the bike works ok just treat the screech like any other motor vehicle "strange noise" and turn the radio up until you can't hear the screech anymore.
Bob - not dead yet
Switch to reserve ~130 miles, fuel panic ~170
saphena is online now   Reply With Quote
Old 04-30-2008   #3 (permalink)
Favorite Bike: two wheeled
Other Motorcycle: Bonneville black
Extra Motorcycle: thumper
Try lubeing speedo cable. When beginning to dry out, they make a noise when first starting out then clear up after a few mins. Don't neglect this or cable may snap (much latter) Havn't done it yet on my Bonnie so not sure what is involved. The ones I've done on previously on cages and bikes were pretty simple to do. The Bonnie should be no different (I hope). If that stops it end of problem.
Bill;
Believe those who seek the truth; doubt those who say they found it.
grumpy_1944 is offline   Reply With Quote
Old 04-30-2008   #4 (permalink)
Favorite Bike: 07 Bonnie Black
Derby Boy's Avatar
Other Motorcycle: 89 Goldwing (PimpZilla)
Extra Motorcycle: can't afford another
When you lube your cable, re-route the cable so it doesn't go thru the upper brake line loop. This will take some bend out of the cable and stop the whirring noise. Bet it only does it below 40deg. F. Do a search on speedo cable and theres some threads with hints for lubing the cable.
"Another Trumpet Rat enslaved to a Bonnie"
07 B/B, AI gone, Bafflectomy, K&N air, Bellmouth,40/115, 1 shim, Naps, Mair Windscreen, GTS-60 Saddlebags, +1 risers
Derby Boy is offline   Reply With Quote
Old 04-30-2008   #5 (permalink)
Derby Boy.
You are spot on with the noise only happening when it's cold. It only happened the past two days when I was driving to work and it was around 31-33 degrees outside.
Didn't know I needed to lube the cable with only 1,800 miles on it, but it will be lubed in very short order.
Thanks.
Old 05-01-2008   #6 (permalink)
Same here...below 30 degrees and I thought the bike was going to blow up. Took out cable, lubed, no more noise.
wyattearp is offline   Reply With Quote
Front suspension noise jon_r Sprint Forum 7 05-09-2008 03:13 PM
Noise in the front chuckpo Twins Technical Talk 7 10-22-2007 10:56 AM
Front Tire Noise HOTRODSRJ The Rocket Science Forum 1 05-18-2007 08:32 AM
Elusive Front-end Noise Raven Twins Technical Talk 8 11-10-2006 10:24 PM
Ticking Noise coming from Engine revolve99 Speed Triple Forum 3 10-03-2005 12:51 PM
