TwoChord,
I have same bags - I believe the rain cover will cover the outside of the bags - sort of like a hair cover! The outside, top and bottom are well covered - if you stretch to its full length and pull tight most of inside is also covered. I have not used in rain but they are fairly secure at speed.
Red and Black T100 - AI removed, Snorkel removed, Uni Filter, Baffelectomy - 2 drilled, National Cycles F16 Screen, 120 Mains, 1 shim
