Most bags will cover the gas cap and filler tube, so you have to remove the bag. I use a magnetic tank bag, so I just lift it up, put it on the seat, fill the bike and then replace it. No problem. I understand that some bags are made with a base that covers the tank and has a hole in it to allow filling. The bag is zipped onto the base, and you unzip it and lift it up out of the way. One thing I don't know is whether the bases are made with a large enough hole, or an off-set hole to accomodate the position of the filler tube on the Modern Classics.
John
_______________
2007 Bonneville Black
