» Links |
03-17-2008
SuperStock Favorite Bike: 1968 bonneville
Posts: 234 Other Motorcycle: 2007 blk/wht bonneville
MC Lift
I finally sprung for a lift,got the Sears one on sale.What a treat! It lifts great and stays put with the straps.I also got the small roller stool.Now I don't have to get down on my 60yr old knees.Got the bike really clean too.Best 60 bucs in a long time.
I have only been drunk twice...the 60s & 70s
2007 T100,Blk/Wht,Ai removed,D&Ds,Snorkel out,restrictor plate out/one shim/ 132mains/40 pilots/3 turns
they do help a lot. especially if you have to pull off the fork, or rear wheel.
try and buy some younger knees while you're at it.
Triumph.... Turns an ordinary man into a mechanic.
2006 Scrambler
2005 CRF 450
1977 Bonneville
1973 Bonneville Bobber
03-17-2008
Lift
Isnt it f***** great!!! I was in heaven when I got mine from the trash!! Saw my ridin buddies sun. Its MUCH lighter than mine but does the same thing- makes doing ANYTHING on the bike so much easier!! I couldnt live w/o it now!! No more bending over!! Just sit there as you said~! Center stand- Bahh Hummbug!! Enjoy the good back after working on the bike!! & have a cold one on me!!
CAPT D
03-17-2008
Formula Extreme Favorite Bike: 2007 Bonneville T100
Posts: 403 Other Motorcycle: 2006 Kymco People 250
I got my lift & roller stool at Harbor Freight. I suspect the Sears units are better quality, but these work fine for now. The roller stool was only $9.99! I also have 60 year old knees, and they are much happier now.
Paul
2007 Triumph Bonneville T100, Tors, xAI, xSnorkel, 120 mains / 1 shim, 40 pilots, 3.0 turns, NH Bellmouth, Works Performance suspension, National Cycle Deflector DX, Scrambler Gel Seat
03-18-2008
Watch out for the oil filter when you use the lift. I usually wind up denting mine from the wood scraps that I use under the frame, then I worry about whether I damaged it internally and replace it for peace of mind.
Also be aware that the Bonneville is very rear-heavy on the lift. Don't remove the front wheel without supporting (or removing) the rear wheel.
Marty
03-18-2008
Lift & filter
My filter doesnt come close to touching anything on the jack? You must be using some larger filter? Why the wood under the frame??? My jack has nice rubber pads on the fingers that hold the frame. Real simple- slide the jack under till it hits the side stand & pump while holding the grip till she sits level , then pump away. If your going to the top- I reccomend using the safety legs! Bud puts his Nightrain to the top w/o the legs & rubs, scrubs etc.No straps as well! Scares the hell outa me!!, but its his bike? This jack laid in someones back yard for years & shows it! I usually only take mine up till the wheels spin- if it let go would hit the ground & settle on the side stand which I leave down . Gotta love em!!
CAPT D
03-18-2008
I use two scraps of wood, about 3x12 inches across and perpendicular to the lift pads. They sit under the frame rails.
This is how it was done by others on this forum when I got started with the lift, but I can't remember why I'm doing it, to be honest. It might have had something to do with clearing the filter (Purolator Pure One 14612), but what happens is that with the bike being jostled the wood ends up under the filter and denting it.
I could avoid this if I were more careful, or maybe I need to re-evaluate whether I need those pieces of wood at all.
PS Another hint for using the lift: It drops rapidly when you release it, unless you release it very slowly and carefully. It's a good idea to have the center stand down when you lower it, if you have one, otherwise the side stand, as the Captain says.
Marty
03-18-2008
Formula Extreme Favorite Bike: Bonneville
I have the larger harbor freight lift. I don't need any wood strips to lift my bonnie. I put one of the lift arms right behind the attachment point for the side stand. It clears the filter and balances well. Don't even have to hold it while I lift it up from the sidestand. It is very stable. The lift has very strong safety catches that ratchet up. After it is at the height that I need it, I ease it down to the first safety catch, so if the pump fails, it is not going anywhere at all. It is a great lift. Normally $72 it is sometimes on sale for about $59.
 2005 Bonnie, TORs and Unifilter, AI gone, Modre's peg kit, headlight & brake modulator, tach, bright leds, NC wind deflector, gaiters, steibel, vmax mirrors, dresser bars, Hagons & Progressives. http://TexasCoastGeology.com
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| How to Lift an 05-08 ST |
shemp |
Sprint Forum |
27 |
02-02-2008 02:02 PM |
| Lift |
Dan18 |
Classic, Vintage & Veteran |
4 |
08-02-2006 04:30 PM |
| need a lift |
CCR |
Modifications & Workshop Talk |
14 |
03-18-2006 12:18 PM |
| How to lift the 05 S3 |
BubbaZ-Isaac |
Speed Triple Forum |
21 |
10-12-2005 06:37 AM |
| How do I lift the S4? |
DaveC |
Triumph SuperSports |
4 |
05-06-2005 09:48 PM |
