Old 10-03-2007   #1 (permalink)
larger front tire ???
I want to put a 110/90-19 on the front. Has anyone used this size? It should fit, but Im worried about the fender bolt clearance. Please let me know if any of you have tried this.
Motoboard
Motoboard is offline   Reply With Quote
Old 10-03-2007   #2 (permalink)
Favorite Bike: Suzuki DL650
uzidzit's Avatar
Other Motorcycle: 2002 bonneville
Extra Motorcycle: '80 Suzuki GS250 TSCC
If it's the metzler
It will work ok, the steering will slow down a noticeable amount though. Check out the pierelli sport demons, by far better than the bt-45s, and seem to be a little grippyer than the lazer techs. just as a bonus they come in the stock size.
"Peter, It seems like you have been missing a lot of work recently, well Bob I wouldn't say that I've been missing it"
ENOUGH, go out and ride!
uzidzit is offline   Reply With Quote
Old 10-04-2007   #3 (permalink)
RonD's Avatar
Other Motorcycle: Triumph Hurricane
Extra Motorcycle: several bsa,s
yes everthing that uzidzit said is obviousely correct in my veiw, i personally think it would be the wrong move to go to a wider tyre, but a good moove to go to pierelli sports demons ..
Regards Ron
Hurricane pictured(Harry)
RonD is offline   Reply With Quote
Old 10-04-2007   #4 (permalink)
I want to go taller to help correct a 7mph speedo error. I am also putting a taller one on the back to keep the front/rear ride height rato the same
Motoboard
Old 10-04-2007   #5 (permalink)
I want to go taller to help correct a 7mph speedo error. I am also putting a taller one on the back to keep the front/rear ride height ratio the same
Motoboard
Old 10-05-2007   #6 (permalink)
just a casual observation, so dont get pissed...but you'll change wheels and tires out rather than subtract 7 from your speedo reading?
even having the speedo recalibrated would probably be cheaper and easier, and would not upset the handling of the bike
G
I just wanted to ride
Old 10-06-2007   #7 (permalink)
I am running a 110/90-19 in the front, and the stock bolts were to close for my liking. I replaced them with button head. I am installing gaters today, if you want a picture of the bolts and clearance. I when to the 110/90-19 in front to better match the 180/55-17 in the rear. now both are radials.
Toyanvil is offline   Reply With Quote
Old 10-08-2007   #8 (permalink)
Favorite Bike: 2003 T100
ohiorider's Avatar
Just theorizing ........
I've played with rear tire sizes on the T100, and am currently running the 150/17 GT501 on the rear. Running std size 501 on the front. This combo feels right for me, though I'd go back to stock 130 on the rear if I wanted quicker handling.
I have never experimented with changing front tire size, but I'm thinking a small change, like going to the 110, would have a much greater effect on handling.
I thinking along the same line as Geoff .... could a speedo shop recalibrate the speedo to make it more accurate? If I recall, the needle is moved by a rotating magnet that works against a 'watchlike' flat coiled spring. Maybe a slightly stronger spring in the speedo would restrain the speedo reading ? I don't know exactly how they do this, but I'd have to think it's be a lot like in the old days when we took a watch in for adjustment when it ran slow or fast.
Good luck however you approach it.
Bob
Old 10-08-2007   #9 (permalink)
Ive tried to get inside the speedo, and the chrome ring on the top is crimped on. I would destroy it and the 7mph error isnt worth tearing the speedo apart. Im going 62 indicated, but the GPS says 55. So a larger front will spin slower and show a lower idicated speed. It wont totally correct it, but it will be better. The taller rear should ballance out the handling. I should receive the tires tomorrow, and after I spoon them on and get them ballanced, I will report on the ride. I will have to break them in before I get too nuts though. I have some stainless lowhead bolts to install, so clearance shouldnt be a problem. We'll all find out soon enough.
Motoboard
new front tire..... ricster Sprint Forum 14 10-23-2007 09:27 AM
new front tire cfbpe Twins Technical Talk 7 07-23-2007 03:27 AM
Mushy front brakes and a larger master cylinder gamecock Sprint Forum 10 11-23-2006 10:26 AM
larger front tire on America rumbler05 Twins Talk 1 06-01-2006 08:48 PM
larger rear tire and rim BTHUMPER Twins Talk 25 04-21-2006 09:53 PM
