Old 07-09-2007   #1 (permalink)
CCR
First, besides cosmetically, the bonnie + thrux have the same basic motor, right? Thrux having a slight larger bore and hotter cams. Any other further comparrisons on this subject would be nice.
Looking at the specs, the bird and thrux have about the same output (give or take). I couldn't find a spec on the compression and bore + stroke of the bird (let me know if you do). But for those of you who have ridden both, give me the differences. All of them. From performance to asthetics to how well one fits better in your garage or whatever. The weight difference is somewhere around 35 lbs (?) but does the thrux feel more nimble?
I guess Im looking for a more classic bike. Simple, straight forward, 2 cyl 2 carbs, AIR COOLED.
CCR is offline   Reply With Quote
Old 07-09-2007   #2 (permalink)
Retired Legend
sweatmachine's Avatar
the 790 motor has hotter cams than the thruxton or bonnie w/ the 865.
I've never ridden a triple, but from your description a bonnie or thrux sounds like just what you're after.
Old 07-09-2007   #3 (permalink)
What does the term "hotter cams" mean?
- David
russd01 is offline   Reply With Quote
Old 07-09-2007   #4 (permalink)
Favorite Bike: My one-and-only '03 Bonne
pabonne's Avatar
Good question! I think it means they're designed to give more HP at higher RPM's?? I know the 790's love to rev and feel pretty flat at low RPM's. The 865 feels stronger off the bottom but no different above 4k IMO.
2003 790 (black, not Black) KARK'd, K&N Cones, Staintunes, 130/42 jets, 2.5 turns out, BC Superbars, CRG LS mirrors, Generic Rubber, 16t
Why? Too many H-D's.
pabonne is offline   Reply With Quote
Old 07-10-2007   #5 (permalink)
Favorite Bike: '06 Bonneville Black
Other Motorcycle: '89 FXR
- David
What he means is the cam profile/timing is different. The 790 cam's have alot of overlap, which makes them a little flat on the lower end..( when compared to a motor with almost no overlap )...yet on the upper end of the rpm range it pull's harder..( than down low..ie: comparing the 790 to itself )
I have 790 and advanced the exhaust cam 1 tooth to lose some of the overlap and make the bike pull a little harder down low...it give's you a end resulting overlap inbetween the stock 790 and the stock 865 setups.
Hated By All....cause thats just how it is.
SCCTrim is offline   Reply With Quote
bonnie v. thrux neuroboy74 Twins Technical Talk 27 2 Weeks Ago 02:34 PM
Bonnie and Thrux needles the same for 07 ?? Laika Twins Technical Talk 6 11-16-2007 10:04 PM
thrux/bonnie tank blue-thrux Club Cafe 4 05-31-2006 10:47 PM
Rearstand for Thrux/Bonnie asphyx9 Twins Talk 1 09-29-2005 05:02 PM
Put up pics of my standard bonnie/thrux/black bonnie mutation faffyface Twins Talk 12 08-09-2005 11:40 AM
