JardineProducts.com
Allstate
Trident-Exhausts.comBikeBanditBritish Motorcycle GearAnnitori DistributingRicor Shocks
Triumph Detroit
Old 07-04-2007   #1 (permalink)
I had heard those on someones bike-really loud. I read where you could install it under the tank, but I think that must have been on an america, because I could not get it to fit, at least in the approved position. The instructions said longetivity would be affected if mounted wrong. So....
I wound up putting it in my now empty air box, using an L bracket attached to a threaded hole where the airbox door for changing the filter is. With the side cover on you cant see it....but you can sure hear it
G
I just wanted to ride
Old 07-04-2007   #2 (permalink)
gt1jimi's Avatar
I mounted my Stebel under the tank of my Scrambler. With the AI valve gone, there was a handy tapped and threaded tab to hang it on. I used one of the bracket parts that came with the horn (plated flat stock, approx. 3/4" by 4", with holes predrilled on either end), after I bent a 5/8" offset in it. This allowed the horn to be centered under the frame tube and away from the tank, in the approved position. Sounds loud (still not good, though: too 'scooter') and is out of the way. Also this frees up the original horn mounting hole for something else (driving light? tow hook? loudspeaker? the tapped hole is lugged up enough to carry something huge - why did the factory do this?)
gt1jimi is offline   Reply With Quote
Stebel Horn Pattern up to give away jeffro Sprint Forum 9 04-21-2008 06:05 PM
I'm ordering the Stebel horn tonight. kkleinert Sprint Forum 22 11-18-2007 10:11 PM
Stebel horn install jthursby The Rocket Science Forum 5 08-11-2007 12:06 PM
Stebel horn install question thefly Sprint Forum 2 06-08-2007 11:33 AM
Stebel Horn Mount biker1059 The Rocket Science Forum 14 10-16-2006 07:58 PM
Harley Davidson Suzuki GSXR Ducati Forum Kawasaki Forum
V-Rod Forum GSXR Forum Ducati Monster Vulcan Forums
Harley Forum Suzuki SV Honda 600RR Kawasaki ZX Forum
Buell Forum Yamaha R1 Honda 1000RR Kawasaki ZX-10R
KTM Forum Yamaha R6 Honda Fury Forums Triumph Forum
Victory Forums YZF-R6 Forum Honda Goldwing Triumph 675
Can Am Spyder Aprilia Forum Sportbikes Forum BMW S1000RR Forum
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
