» Links |
05-25-2007
My front pads are shot approaching 10K miles. Lots left on the back though.
I'm going to order up the sintered pads from Brent today but just curious about how many miles the rest of you got from the original fronts?
FYI - most of my riding is on backroads to/from work. Pretty regular brake application.
P
I have heard the song of the Sausage Creature!
Site Supporter Retired Legend Favorite Bike: 904cc Bonnie w/magwheels
around 10k miles on the front, but I probably should have replaced them at 8k.
I think I got about 12-14k out of the rears, but should have replaced them at 10k, they were totally gone when I pulled them out.
05-25-2007
World SuperBike Favorite Bike: 2008 Victory Kingpin
Posts: 2,125 Other Motorcycle: 2006 Victory Vegas Extra Motorcycle: 2005 Speedmaster (Ret.)
My bike is over 11,000 and the brakes seem ok although I notice the wear since when they were new.
FYI, I try to rely on engine braking whenever possible.
Kevin
Luceo Non Uro
NJ USA
05-25-2007
+1
05-25-2007
I clearly don't which is yet further evidence that I need to get off the streets and onto a track so I learn how to do the fast thing right.
"Do right, then do it fast".
P
05-25-2007
I also try to use engine to slow down when possible.
"If you're gonna be dumb you gotta be tough"
05-25-2007
Still original at 19825 miles. The front looks to be only down by 25% and the rear looks to be about 50% down...what can I say...I ride in the sticks and only use my brakes when I have to...the flat lands is kinda easy on the brakes if you are not trying stoppies. :-D
Larry
Larry
05-25-2007
Site Supporter Team Owner
That sounds like the ideal situation, Larry!
Mine has seen mixed urban, rural and semi-rural riding. Just had the 10K inspection done, and still have 25% of the front and well over 50% of the rear pads left...which surprised me, as I don't think I use the front brake that much at all. (On the other hand, Bonnie had several hundred miles on her before I came along, so who can say what the initial usage might have been.)
Anyway, if one does use a certain amount of engine braking, it definitely helps pad life. And if you're doing it right (!) it doesn't appreciably accelerate clutch wear, either. It's not the sliding friction of the clutch you're depending on with engine braking.
John
05-25-2007
SuperSport Favorite Bike: 2004 Bonneville America
Posts: 1,334 Other Motorcycle: 1976 T140V {Bonneville} Extra Motorcycle: 68'YCS1E,71'CT90,82'XL80
I mostly travel in town. 6000 miles to the rear so I changed them all.
05-25-2007
At 6000 miles, lots still on the front, the back might have 2000 miles left.
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes, Unifilter, no snorkel, 120/40/Thrux needle/1 shim/3 turns, fly screen, tacho, D9 gauge panel, center stand, Ikon 7610s, Hagon fork springs, gaiters, Pirelli Sport Demons, 3 seats.
