HSR 42's almost installed - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-29-2007, 01:04 AM   #1 (permalink)
got my kit last week and attmepted to install them before the rain thursday night. well the rain beat me and i did not finish. it is almost done tho and i should have a test ride on monday.
there has been a lot of talk about the carbs and the kit, for one i have read a lot about the 42's and came to the conclusion they are a great set of carbs. i also talked to everyone i could find who is currently running them and they seem to work great, especially with the future mods i have planned. the price is a big factor. i ended up buying the carbs over the belt drive so i guess that justified it in my mind. the kit comes with a lot of stuff includint a very nice set of billitt grips, there are a lot of little misc. pieces in the kit and also a nice set of billitt manifolds, everything i saw makes it seem a bit more worth it, including the top notch assistance from bill. so far i am very happy with the kit, after i get the fuel lines run and my valves adjusted i will report on how they perform, then i will re dyno the bike.
to be continued.....
Frank
ftl40 is offline   Reply With Quote
Old 04-29-2007, 01:11 AM   #2 (permalink)
bonnieblackinfl's Avatar
:upthumb: You are almost there!
Greg
bonnieblackinfl is offline   Reply With Quote
Old 04-29-2007, 08:42 AM   #3 (permalink)
Favourite Bike: My 904 Bonnie
keef's Avatar
Extra Motorcycle: dya mean the one outside?
I'll be interested to see the dyno reading.
What other mods have you made?
Rides:
2001 Bonnie: Mods - Wiseco 904; KARK; Megas; Hagon Nitros & Progressives, etc.
The Wife: Mods - haircut; earrings; children
keef is offline   Reply With Quote
Old 04-29-2007, 02:59 PM   #4 (permalink)
i have the freak and thunderbike pipes, my last dyno was 62 at the wheel. yes the big bore is in the future
Old 04-30-2007, 09:21 PM   #5 (permalink)
i got the bike running, i get no pops at all like i used to. low range feels great but i get a bad bog in the mid. i will play with the jetting and when i get it figured out post more
Old 05-01-2007, 10:48 PM   #6 (permalink)
Favourite Bike: 03 T100
mikeinva's Avatar
i have them on my bike. you will loose alot of the bog when you get the main jet rich enough.I have a stock 790 with predators and the brit custom ing module on mine i ended up going with the 67 niddle in 3rd slot 25 polit and a 160 main that gave a mixture of between 13 and 14 to 1 all the way through. you cant just dump the throttle with these carbs and a stock motor but if you roll the gas on slow look out and hold on.mine makes right at 65 hp at the rear well at 7500 rpm ( THAT IS AS FAST AS THE HD dino guy wanted to take it and it was still going up.they are great carbs and bill knows his stuff.next comes some head work and big bore and maybe a stroker 1200 if wife dont div. me for sending money lol
mikeinva is online now   Reply With Quote
Old 05-02-2007, 12:07 AM   #7 (permalink)
HiVel's Avatar
See my post on pg. 2 of the "which Jap bikes use the same carbs" thread.
I got 65.2 rw HP with 135/42, 3 turns out which was a very lean A/F ratio.
Running better now with a 150 main. Stock Carbs!!
2007 Tiger "Old Blue"
2004 Thruxton "Big Red"
2006 Sprint ST ABS "The Blue COW"
HiVel is offline   Reply With Quote
Good Bye HSR 42mm....Hello HSR 45mm Bottle_Fed Twins Technical Talk 30 02-15-2008 12:15 PM
DYNO with mikuni 42's ftl40 Twins Talk 6 08-12-2007 02:14 PM
HSR 790 Dyno is in!! bonnieblackinfl Twins Technical Talk 16 01-25-2007 09:57 AM
HSR 790 is on the road!! bonnieblackinfl Twins Technical Talk 7 01-24-2007 09:59 AM
Mikuni HSR 42mm bonnieblackinfl Twins Technical Talk 18 01-10-2007 06:48 PM
