BikeBandit
Old 04-23-2007   #1 (permalink)
I was in the process of rejetting my carbs when Ifound it difficult to get at and remove my pilot jets. They seem stuck down there. Is there some special tool I need? Do I need a certain screwdriver?
I'm think I may have slightly stripped them and am afraid to proceed without some advice and guidance.
brownbomber is offline   Reply With Quote
Old 04-23-2007   #2 (permalink)
they are tight, usually, and you need a screwdriver that has the perfect sized blade, with no damage so its a perfect fit. This will usually do it. If they are stripped, you may have trouble.
I'd get the right screwdriver, push real hard, and try again. If those buggers stripout on you, it may require a trip to a machine shop to get them out without further damage
G
I just wanted to ride
Old 04-23-2007   #3 (permalink)
Favorite Bike: 2003 Triumph T100
I used a brand new Craftsman slotted screwdriver that I had to file the sides to make fit. It must be full width and sharp to get enough purchase to loosen. After that, it's like Geoff says: grab hold of the carbs, push the screwdriver in hard, and tuuuuuurn leeeeeeft...
Old 04-23-2007   #4 (permalink)
Favorite Bike: 04 T100 blue/white (his)
Wooly's Avatar
Other Motorcycle: 07 T100 red/black (hers)
Extra Motorcycle: 1971 Yamaha DT2 250
In addition to the very good tips that Geoff and Sheedog have already posted I also suggest using the longest possible screwdriver that will still fit the slot in the jet correctly.
The extra blade length permits much more turning torque than a shorter one and when the screw releases it is usually with a satisfying 'crack'.
Another tip is to use a small amount of valve grinding paste on the blade tip, gets a good grip that way.
Good luck!!
Phil.
Wooly is offline   Reply With Quote
Old 04-23-2007   #5 (permalink)
I recommend using a mirror and flashlight to inspect the pilot jets for damage. If damaged, you may be looking at getting professional help if you are dead set on changing them. If not damaged, I recommend being very careful and doing the job by feel with the proper sized screw driver or bit. I used a 1/4 inch ratchet with a new slotted screwdriver bit to take mine out the first time--they are overly tight in some cases.
You don't say why you are changing the pilot jets or what year bonnie you have. I have an '03 with NH Togas and the airbox removed and the stock pilot jets (40's) would work just fine with these mods. The '03 is a 790cc--I'm not sure if the same applies to the 865cc motors. If I had your problem and one of the pilot jet screw-slots was damaged, I would leave them in and forget about changing them as long as I could adjust for the proper Air/Fuel ratio with the pilot screws. :-D
Larry
Larry
Old 04-23-2007   #6 (permalink)
Favorite Bike: 2001 Bonneville (cafe)
Other Motorcycle: 2003 Honda XR650L
Extra Motorcycle: 2008 Suzuki V-Strom 650
Funny this post should appear today. I gutted my airbox and rejetted today, and I had a b!t©h of a time getting the stupid pilot jets out. Had to make two trips to the hardware store to finally find a screwdriver that was just the right size. But eventually I got the pilots out and installed 42s.
A small inspection mirror like dentists use is immensely helpful to give you some idea of whether you're actually turning the pilot jet or just mangling it.
--mark
Bennington Triumph Bash
Bennington, VT May 30-June 1, 2008
Thanks to all who attended!
Do you keep one bullet left for yourself, for when it's all over and done?
markbvt is offline   Reply With Quote
Main Jets & Pilot Jets ggRAT Club Cafe 21 11-13-2007 08:52 AM
pilot jets sean_x Hinckley Classic Triples 2 06-09-2007 05:51 PM
pilot jets bikefactor Twins Technical Talk 6 02-27-2007 05:37 AM
pilot jets roccopeterbilt Twins Talk 2 05-04-2006 09:31 PM
Pilot jets Saigon5 Hinckley Classic Triples 3 08-17-2005 07:44 AM
