Old 04-04-2007   #1 (permalink)
Favorite Bike: 2003 T100
ohiorider's Avatar
I'm considering doing the flat black paint treatment to my exhaust headers, and would like to use a reverse header in the same color, but with polished aluminum (chrome?) end caps.
Couple of questions for you exhaust gurus.
1. Is D&D the only game in town for this style muffler? I like the look but want something with only slightly more volume than the TORs I'm currently running.
2. Do the aftermarket mufflers use the Triumph muffler mounts, ie, do I remove the mounts from the TORs and install them on the aftermarket mufflers? It's been over year since I installed the TORs, and I think I recall removing the mounts from the factory pipes and bolting them onto the TORs.
Bob
[ This message was edited by: ohiorider on 2007-04-04 15:02 ]
Old 04-04-2007   #2 (permalink)
all the aftermarket exhausts I have heard were much louder than TORs, so finding one only a little louder might be tough.
Predators come as reverse megs, emgos make them, staintunes also. there are others a s well
G
I just wanted to ride
Old 04-04-2007   #3 (permalink)
I just loves me Staintunes! Bike came with them but I'd buy them just for the coolest name in pipes.
voila
[ This message was edited by: FlungPup on 2007-04-04 15:47 ]
Root Hog or Die!
FlungPup is offline   Reply With Quote
Old 04-04-2007   #4 (permalink)
Favorite Bike: 05 Bonneville T100 B/W
wenzel850's Avatar
Bob,
If you go to the D&D website, they appear to be making better baffles for their pipes. Also Thunder City makes baffles that fit D&D's. one more thing. I was told by Fattratt that if you take out the stock D&D baffles, and cut off their packing, and repack with a good insulation hold it on to the baffles with wire, plus pack inside of the cans themselves that the pipes become alot quieter.
Quentin
"01-20-2009 I can't wait"
wenzel850 is offline   Reply With Quote
Old 04-04-2007   #5 (permalink)
not to hijack this thread b/c I'm interested in the flat black treatment as well, but does anyone have any tips on how to get the end cap off of the D&D's? After taking the allen screws out and trying just about everything to get the ends loose I still haven't been able to.
Tricks to these puppies??
-craig
stone is offline   Reply With Quote
Old 04-04-2007   #6 (permalink)
wenzel850's Avatar
Craig,
I used a medium sized flat screwdriver and put it into the seams between the end cap and the can. I worked it slowly until I was able to move the caps with my hand and then they came off fairly easy. Just do it slowly so as not to scratch your chrome.
Quentin
Old 04-04-2007   #7 (permalink)
Thanks Quentin good idea, I'll try the screwdriver trick with some thin tape around it to avoid scratching.
cheers
-craig
Old 04-04-2007   #8 (permalink)
Favorite Bike: My one-and-only '03 Bonne
pabonne's Avatar
Another nod to Staintunes. They are NOT loud pipes (until you get on them). :razz:
As far as I know they only come in the polished finish however.
2003 790 (black, not Black) KARK'd, K&N Cones, Staintunes, 130/42 jets, 2.5 turns out, BC Superbars, CRG LS mirrors, Generic Rubber, 16t
Why? Too many H-D's.
pabonne is offline   Reply With Quote
Reverse controls? stimm99 Classic, Vintage & Veteran 13 01-12-2008 05:11 PM
Reverse shift arashi858 Speed Triple Forum 16 12-29-2006 08:30 AM
Reverse Steering johnsime Twins Technical Talk 22 10-12-2006 02:57 PM
Head installation in reverse evadbone Classic, Vintage & Veteran 12 02-02-2005 11:09 AM
Reverse nakedness? Speed Triple Forum 3 09-27-2004 01:16 PM
