BikeBanditMotorcycle.comTrident-Exhausts.comAdvanstarMotorcycleShows
Old 03-02-2007   #1 (permalink)
gcm978
In trying to replace a fork oil seal I have run into one heck of a problem. The bottom bolt the holds the bottom rod bushing is not coming undone. I have used an air drill, shoved a piece of wood in the tube, and called the thing every bad word in the dictionary. Does anyone have any old "tricks" for getting this bold free from the bushing?
Old 03-02-2007   #2 (permalink)
Favorite Bike: '06 Bonneville Black
Other Motorcycle: '89 FXR
I'm not sure I understand which bolt is fighting you...
Picture?
[ This message was edited by: SCCTrim on 2007-03-02 08:50 ]
Hated By All....cause thats just how it is.
SCCTrim is offline   Reply With Quote
Old 03-02-2007   #3 (permalink)
gcm978
The bolt inside the bottom of the fork. It goes inside the fork and holds the bottom bushing in place. Even the Haynes manual says it is tricky to get out, but this was insane. Perhaps heating the bolt to losen the thread lock, but I would think someone has an old trick or two.
Old 03-02-2007   #4 (permalink)
Favorite Bike: 2001 Bonneville (cafe)
Other Motorcycle: 2003 Honda XR650L
Extra Motorcycle: 2008 Suzuki V-Strom 650
I had no problem removing these bolts in order to use the holes to drain fork oil. I take it the problem you're having is that the internals are spinning with the bolt as you turn it?
I would try reassembling the fork and reinstalling the cap so that there's downward pressure on the damper rod, then trying again to unscrew the bolt. If you haven't tried that already...
--mark
Bennington Triumph Bash
Bennington, VT May 30-June 1, 2008
Thanks to all who attended!
Do you keep one bullet left for yourself, for when it's all over and done?
markbvt is offline   Reply With Quote
Old 03-03-2007   #5 (permalink)
As a last resort triumph sell a special tool to hold the damper rod while you remove the bolt.
Cheers y'all, Cyn-
First you take the test,
then you learn the lesson!
Members Album
CYNCRZR is offline   Reply With Quote
Old 03-03-2007   #6 (permalink)
Other Motorcycle: 66 Bonnie Chop
Drop by your local shop and they'll have it out in 5 minutes.
Al
ssjones is offline   Reply With Quote
Old 03-03-2007   #7 (permalink)
gcm978
Local shop is no fun. Finally just took a impact wrench and it was out in a jiff. Thanks to all.
Old 03-04-2007   #8 (permalink)
Nice job! How long an extension did you need?
Al
Forks KitNYC T3 Sport / Touring Forum 8 08-09-2007 10:13 AM
f3 forks ScruffyB Club Cafe 18 01-20-2007 12:55 AM
MX forks on 06? jaak Tiger Chat 0 12-12-2006 09:37 AM
New S3 forks losingfight Speed Triple Forum 10 04-28-2006 01:25 PM
Forks nyolds Daytona Deliberations 2 02-26-2005 07:31 AM
