mythbusters: mittens are warmer than gloves - Triumph Forum: Triumph Rat Motorcycle Forums
Sponsored by: National Powersports Distributors
post #1 of 18 (permalink) Old 01-14-2007, 01:41 PM Thread Starter
After trying different equipment to be comfortable in extended hwy riding in temps in the low 30s, I could keep everything decent except for my finger tips. Tried better winter gloves and glove liners that helped but it still got painful on the finger tips.
So a friend told me to try good mittens. I thought they would be hard to ride with so never considered them. I bought some winter, water-proof mittens and did a test today.
When I left the house about 8:30 am the temp was 35 degrees with a constant light rain. I put on my thick gloves with silk liners and thicker liners over them. Within 10 minutes my finger tips were uncomfortable already and I was still in the neighborhood area. The hand control feeling was not good but manageable.
I then put on the mittens over the same double liners. They were warmer after riding for about 10 minutes but I got cramps in the webs of my hands between the thumbs and pointing finger. So I took off the silk liners to allow more room. Much better then and very good hand control feeling.
After about 15 minutes of hwy riding my finger tips started to get chilled, so I just tried letting my finger tips not grip and point more straight so just my palms were griping. This allowed more of an air gap all around the finger tips. WALLAH!!! My finger tips got warm again except for my thumb tips. So I extended my fingers over my thumbs and tucked my thumbs under the finger air flow so my thumb tips were shielded by the mitts. I rode for about an hour and a half like that on the hwy and ALL was comfortable as long as I didn't grip with my finger tips. The gloves gave me no relief no matter what I tried.
So if you were able to stay awake through this boring post of mine, it is true, mittens ARE better than gloves, especially when the correct grip technique is found.
Just got home and the digital temp reads 37 degrees so the weather stayed consistent.
black-bonnie is offline
post #2 of 18 (permalink) Old 01-14-2007, 02:14 PM
I admire brave souls who are not afeared of cold temps!
Your perception of mittens must be true, I've never seen "snowmobiling gloves", just mittens. Lucky for you, riding is a possibility. The past few days in western PA have been in the 40's and 50's but raining. I'll pass on wet roads with gravel till I get new tires on.
Talishar is offline
post #3 of 18 (permalink) Old 01-14-2007, 02:29 PM
Have you looked at 9v solutions? I understand now why guys up north get electric grips. And you use an electric vest right?
2005 Thruxton
2000 Speed Triple
whoa is offline
post #4 of 18 (permalink) Old 01-14-2007, 03:06 PM Thread Starter
Yes, an electric vest I use. There has to be something, somewhere that touches you that generates heat besides yourself if you are in prolonged periods of cold without being able to move to generate heat. In affect, the electric vest helps keep the whole body warm as long as they are insulated.
From what reading I've done about 9v batteries, they use up a lot of batteries and are not worth it.
I'm just very happy to finally find a solution for my finger tips that does not require electric gloves, electric grips, hand guards or Hippo Muffs.
Now if I could only find motorcycle tires with spikes so I could ride on the icy roads that are coming tonight. LOL.
post #5 of 18 (permalink) Old 01-15-2007, 10:21 AM
Main Motorcycle: 08 Bonneville T100 C/S
wenzel850's Avatar
Bonnie-Black,
Are you a smoker ? I found when I smoked that I needed extremely good gloves to keep the finger tips from hurting and getting the first stages of frost-bite.
I used leather insulated skiing gloves, which stopped all the pain in my finger tips. At the time I was riding 35-45 mins
at highway speeds (in NJ that's 75(+)) and then 10 -15 mins in stop and go traffic.
But when I quit smoking alot of the above problems went away, the blood was able to circulate better in my fingers.
Ride safe,
Quentin
wenzel850 is offline
post #6 of 18 (permalink) Old 01-15-2007, 11:05 AM
Main Motorcycle: 2005 Bonneville
Other Motorcycle: 2005 V-Strom 1000
Extra Motorcycle: 2003 Trophy 1200 (wife's)
On 2007-01-15 08:21, wenzel850 wrote:
Are you a smoker ? I found when I smoked that I needed extremely good gloves to keep the finger tips from hurting and getting the first stages of frost-bite...........But when I quit smoking alot of the above problems went away, the blood was able to circulate better in my fingers.
Hmmm..... very interesting, not smoking means more oxygen in the blood? Blood better able to fuel the cellular level processes that fuel the body and warm it as a by-product? Just guessing, don't know the physiology. Anyone here know this stuff?
jstark47 is offline
post #7 of 18 (permalink) Old 01-15-2007, 11:43 AM Thread Starter
Am I a smoker? Of what?
No I don't smoke but I'm on the lean side. Not much body fat for insulation. I've always had cold finger tips when the weather got chilly.
That is an interesting observation though about smoking.
post #8 of 18 (permalink) Old 01-15-2007, 04:35 PM
jstark,
Not up on all the physiology of it but, long term smoking does effect circulation in the extemities. I believe it's a constriction of the blood vessels that is a by-product of nicotine, and increased carbon-dioxide levels in the blood stream.
I used to smoke, (20 years) and quit about six years ago. I don't really experiance the loss of profussion (oxygen-circulation)in my limbs, but *****, breathing can be hard.
Talishar is offline
post #9 of 18 (permalink) Old 01-15-2007, 05:43 PM Thread Starter
Question:
For all the non-smokers out there; are you saying that your finger tips don't get cold riding on the hwy in 35 degrees on a rainy day?
post #10 of 18 (permalink) Old 01-15-2007, 07:05 PM
Good posting. Dressing in layers requires a little air space to be effective. Same thing extreme weather gear manufacturers refer to when comparing down when it gets wet/compacted/no air vs other materials that maintain insulation qualities even when wet.
Glad you got it worked out, fun to ride year round when you can make it relatively comfortable.
BobW
bobw3592 is offline
Carb warmer Fyr Twins Technical Talk 35 12-14-2007 08:16 PM
carb warmer question klc Twins Technical Talk 7 09-16-2006 05:30 PM
carb warmer... Troh23 Twins Technical Talk 8 08-11-2006 11:41 PM
inner gloves / summer gloves all year round.... Treehugger Triumph SuperSports 8 01-05-2005 06:19 AM
Protective Mittens? shawboy Sprint Forum 6 05-19-2004 04:23 PM
