BikeBanditMotorcycle.comAdvanstarMotorcycleShows
Closed Thread
Old 11-10-2006   #1 (permalink)
Favorite Bike: '06 Bonneville Black
Other Motorcycle: '89 FXR
I have had the chance to spend a little time with the bike now, and also was able to get it back on the dyno today. Suprisingly the A/F really wasnt that far off...even with the accel pumps enabled.
For comparison the 1st sheet is the bike prior to having the exhaust cam advanced 1 tooth, and with the stock cvk carbs.
75.36 hp
59.93 lbft of torque
The sheet below is from today, this is the same dyno as the sheet above.
82.30 hp
61.06 lbft of torque
The carbs still need some work regarding tune...the bike is lean at idle...and rich around cruising speeds of 65/70 mph. We dropped the main's from 145's to 142.5 to bring the bike closer to 13 at cruising. I have the needles setup on notch #5...they are raised all the way up. I backed out of doing anymore tuning on the dyno and bought another pair of needles. After I get those in I'll get the bike back to the shop for another run...and maybe swap out the pilot's.
While the peak torque is nearly the same, the curve is much flatter....the bike pull's great and is a thrill to ride.
Comparing these carb's to the stock cvk's is difficult regarding drivability...rather like comparing say...a Sport bike to a Harley. Two totally different piece's of equipment...I don't believe...( I may be wrong )...that either the mikuni's or the fcr's will ever hold the level of drivability of the cvk's. These carbs..( mikuni's/fcr's )...simply are not constant velocity carbs.
The power come's on rather abruptly, not to the point where it's undriveable by any means...I do find myself now having to be much more self aware of how smooth I am with the throttle however. Learning smooth throttle control is a good thing.
I'd recommend these carbs to anyone serious about building hp.
No telling at this point whether or not advancing the exhaust
cam made any difference on paper...as I had said before...I doubt it made any real difference on paper. The real benefit however is by the seat of the pant's feel of the bike.
Hated By All....cause thats just how it is.
SCCTrim is offline
Old 11-10-2006   #2 (permalink)
Favorite Bike: My one-and-only '03 Bonne
pabonne's Avatar
I was wondering when we'd see this. That's some serious power... Impressive that you've managed to get this from the Bonne's powerplant. Definitely shows the rest of us what can be done. Great work. :upthumb:
2003 790 (black, not Black) KARK'd, K&N Cones, Staintunes, 130/42 jets, 2.5 turns out, BC Superbars, CRG LS mirrors, Generic Rubber, 16t
Why? Too many H-D's.
pabonne is online now
Old 11-10-2006   #3 (permalink)
HiVel's Avatar
Looks like the bike is all done at about 6,500. This would bother me as I am an inveterate revver of engines=twist em till they cry uncle! Do you think some other cams ( I do not know who or where to get some)would move the HP curve and also increase it to around 85 HP. My bike has the Procom module to increase red line -do you see the need for that yet? Seems like the driveability situation you describe wpould make th ebike harder to go fast on a curvy road. Perhaps it would be best for just racing in a straight line?
Love the carbs and would like to get some anyhow!
Anything worth doing is worth doing to excess!
2007 Tiger "Old Blue"
HiVel is offline
Old 11-11-2006   #4 (permalink)
The bottom scale is not properly scaled to show the correct rpms. The dyno operator took the bike to 8000 on this run.
SCCTrim is offline
Old 11-11-2006   #5 (permalink)
HiVel's Avatar
Now we are cooking!!
HiVel is offline
Old 11-11-2006   #6 (permalink)
Retired Legend
sweatmachine's Avatar
Very impressive, 80+ well documented horses at the wheel. Really, that puts you next to any stock bike claiming 100 hp, and probably above any 100 horse bike in the torque department.
Nice stuff. I can't quit thinking about the stroker kit. I think I may have to finish up my XS and sell it for some stroker money...seriously. A stroker with those carbs should be good for at least 90hp and 75 ft lbs...mmm
color me jealous.
sweatmachine is offline
Old 11-11-2006   #7 (permalink)
Just back in from adjusting the carbs abit...managed to finally properly disable the accelerator pumps and the bike love's it. Snappy acceleration, pull's like a frieght train.
Don't let anyone tell you these carbs dont work...they are awesome.
Final settings:
97 needles on #5 position
20 pilots
142.5 mains
7/8 turn out on air screw
Machine...don't talk yourself out of the 904 kit due to the small gain in displacement...the added torque / hp from the increased compression ratio is where it's at.
Based upon what I've done to my bike, you should expect roughly 20 horses more or less from a 904 kit and carbs.
SCCTrim is offline
Old 11-11-2006   #8 (permalink)
Favorite Bike: 904 Bonnie/Daytona 675
Brooksie's Avatar
SCC-do you think you can get comparable gains with 35mm Kehins?
Brooksie is offline
Old 11-11-2006   #9 (permalink)
I've never ran the cr carbs, so my thought's on this are speculation. My answer would be no, while I'm sure the cr carbs do boost performance, seeing how they are the same size as the stock carb's I do not believe they would give the same performance advantage as the mikuni's. I would also assume the mikuni's flow alot more air than the cr's due to the difference in size...ie: 35mm versus 42mm.
Again this is only speculation....just make's sense to me...more air, more fuel, more power.
BTW...I was informed that the reason the rpm's are not correctly scaled in the 2nd dyno sheet is due to the fact that the Gately's had their race bike on the dyno just prior to mine. Rob neglected to reset the rpm's for a 8000 limit..( the race bike redline's at 10000 )..Hence the improperly calculated readings.
SCCTrim is offline
Old 11-12-2006   #10 (permalink)
SCCTrim,
Very interesting! Not on the forums much anymore and today is my first visit to this new segment after the split. I live just north a Allentown and it appears that we have some things in common. I have had the 42mm HSRs on my '02 America for well over three years now and I'm just finishing a ground up resto of a '69 BSA Rocket 3!
Initially, I really didn't see much of a power gain with the Mukunis although they looked a heck of lot better and they allowed me to lose the stock air box and aquire a very useful "trunk" under the seat!
I always had a problem with the bike running too rich. I can't even count the number of times that I've had these on/off of the bike and the number of jet combinations that I tried. Even custom ordered leaner than normally available jets from Mikuni! Still the bike had plenty of power and "Harley hunting" was real easy! LOL! Always thought (and still do) that these carbs are just too big for the bike.
Two winters ago, I dropped in the Weisco 904 big bore. The lean problem got a little better and power got better. Big surprise, huh? Last winter I dropped in a set of British Custom street cams. Without touching the ultra lean carb settings this combo finally got the bike to stop blowing black soot out of my Sceptre pipes but only after I also disabled the accel pumps!
I dynoed the bike a few months ago and got almost the exact reverse results that you did. 65 HP and 83 lb/ft of torque!! Weird, huh? We ran the bike twice to be certain and we also had run my '05 Rocket 3 just before this with the expected results so I don't think there was a problem with the dyno. This bike drips torque!! Seat of the pants confirms the results as well. It's actually difficult to shift into any gear including fifth without having the front end jump! I love it!!
Perhaps this spring we ought to meet up somewhere and swap rides. Might be interesting! I'm still thinking that the Mikunis are really too big.
BYW, I put a Hyde 850 big bore and a set of MAP street cams in the Beezer "while I was there". I just can't help myself. Sigh!
Cogito ergo equito
Bob
TBAbob is offline
Closed Thread
Good Bye HSR 42mm....Hello HSR 45mm Bottle_Fed Twins Technical Talk 30 02-15-2008 11:15 AM
42mm Mikuni HSR's....and being told no SCCTrim Twins Technical Talk 17 08-23-2007 11:18 AM
HSR's SHIP TODAY!!! bonnieblackinfl Twins Technical Talk 11 01-13-2007 11:50 AM
Mikuni HSR 42mm bonnieblackinfl Twins Technical Talk 18 01-10-2007 05:48 PM
Mikuni 42mm HSR's installed... SCCTrim Twins Talk 8 11-03-2006 12:48 PM
