Closed Thread
Old 11-01-2006   #1 (permalink)
I just noticed that my headlight is brightest at idle, which is 1200 rpm's on my 2005 T100. As I raise the rpm's it get dimmer. Not a lot but definitely dimmer. Is this normal?
Thanks
CC
PA-guy is offline
Old 11-01-2006   #2 (permalink)
Favorite Bike: '06 Bonneville Black
Other Motorcycle: '89 FXR
Not sure what would cause that, if your still running the stock headlight bulb I would change it out for a silverstar or something similar however. My stock bulb was like....a candle at night.
Much better since I upgraded the bulb...although I cant say I recall having that issue with my stock one.
Hated By All....cause thats just how it is.
SCCTrim is offline
Old 11-01-2006   #3 (permalink)
Yes it is, I don't know why or how but it does.
Darcy
-Darcy-
BIR #174
"My eyes.....the goggles do nothing!"
Rainier Wolfcastle
DickBender is offline
Old 11-01-2006   #4 (permalink)
Favorite Bike: 2001 Bonneville (cafe)
Other Motorcycle: 2003 Honda XR650L
Extra Motorcycle: 2008 Suzuki V-Strom 650
That's odd. Mine does the opposite. If I'm riding in town at night, stopped at a traffic light, it gets noticeably brighter as I rev the engine, then dims again as it drops to idle.
--mark
Bennington Triumph Bash
Bennington, VT May 30-June 1, 2008
Thanks to all who attended!
Do you keep one bullet left for yourself, for when it's all over and done?
markbvt is offline
Old 11-01-2006   #5 (permalink)
Retired Legend
sweatmachine's Avatar
do yourself a favor, go to the local auto parts store and pickup a replacement bulb with the reflector etc.
Mine cost 12 bucks and is 3 times as bright, if not more. Totally worth it, and took maybe 30 minutes to install.
I don't have the model # in front of me, but I could get it if you're interested.
sweatmachine is online now
Old 11-01-2006   #6 (permalink)
Favorite Bike: 05 Bonneville T100 B/W
wenzel850's Avatar
Pa-guy
Here is the part number for the brighter bulb I'm using in my bike.
H6024 XtraVision Headlight
High Performance Halogen Sealed Beam Headlight - Dual filament for both high beam and low beam - part number: H6024XV
I think it cost like sweat said its about $12-13.
I got it at Advance Auto.
[ This message was edited by: wenzel850 on 2006-11-01 17:10 ]
Quentin
"01-20-2009 I can't wait"
wenzel850 is offline
Old 11-01-2006   #7 (permalink)
Favorite Bike: 2003 T100
ohiorider's Avatar
Bike electrical systems are not my strong suit .... but I think you might also want to check alternator output and how the voltage regulator/rectifier is functioning properly, if the light drops off significantly as you increase the rpms.
Unfortunately, Haynes says there are no tests available for the regulator/rectifier (that little waffle iron looking thing under the headlight).
Someone on this site is sure to know some general rules of thumb for ck'ng this part of the charging system.
BTW - I did change out the stock lamp for one of the Sylvania 6024 automobile units .... lots better. All you lose is that dim little parking light. There's nothing wrong with the stock H4 bulbs, but our stock setup has either a poorly designed reflector, lens, or both.
Bob
ohiorider is online now
Old 11-01-2006   #8 (permalink)
Favorite Bike: 2008 Victory Kingpin
Silverado57's Avatar
Other Motorcycle: 2006 Victory Vegas
Extra Motorcycle: 2005 Speedmaster (Ret.)
Quentin is right, the H6024XV is the goods.
Kevin
Luceo Non Uro
NJ USA
Silverado57 is offline
Old 11-01-2006   #9 (permalink)
ohiorider's Avatar
When I went out to the garage this evening to confirm which model Sylvania headlamp I was running, big surprise. Low beam was out! Weird how that happens .... I'd just done a walk around a day or so ago to ck all lights, etc. So, off to AutoZone for the replacement. Everything went smoothly until the last two screws .... but after some putzing around, it's back together.
Bob
Old 11-01-2006   #10 (permalink)
Put a digital volt meter across the battery terminals & check the voltage. That will let you know what the alternator is doing. But there won't be anything you can do about it. The only thing that will cause a bulb to get dimmer is a lower voltage. Why it is getting lower who knows. Has to be the regulation which means the regulator or diodes.
Get a Cibie or Marchal 7" headlamp & put a 55-100 watt bulb in it. You will love it.
357bob
357Bob is offline
Closed Thread
RPM's @ 80 unitedrocker Twins Technical Talk 5 07-30-2007 12:30 PM
RPM's / Redline...?? glw Classic, Vintage & Veteran 9 05-30-2007 08:30 AM
RPM's KarmaPunk1 Speed Triple Forum 5 06-01-2006 08:01 PM
RPM's Whisperinsmith Twins Talk 8 06-29-2005 08:13 AM
rpm's tradedinmyharly Speed Triple Forum 24 10-08-2004 06:50 PM
