Closed Thread
Old 10-30-2006   #1 (permalink)
A few people on the forum have the Manic Salamander universal bar end weights and from what I hear they work really well at reducing vibrations. But I have the M-bars with the threaded ends and I was interested in finding weights that would bolt on to factory (or factory-sized aftermarket) bars. I looked around and I was able to find a few bolt-on bar end weights for the bonnie. Unfortunately, almost all the weights I found are very light and wouldn’t work much better than the aluminum end-caps. None of them come close to the 13-ouncers from Manic Salamander.
I emailed Paul Ashman at Manic Salamander and asked whether he would be able to design bar ends that would fit directly onto factory (or same-sized aftermarket) bars. He is willing to make a project out of it as long as he knows that people are interested in the product. Check out the item at ‘manicsalamander.com’ and if you want Paul to design the weights for our bikes you can express your interest by emailing Paul at ‘pashman@manicsalamander.com’.
Also, someone donated a Bonnie bar to Paul a while back, but he still needs the end caps to help him design the weights. If anyone out there is not using their end caps, could you please mail them to Paul?
Cheers!
MODS: M-bars, Triumph Engine Guard Bars, Sprint/Emgo Pipes, Stock Mains with 42 Pilot Jets, AI Removed, & Iridium Plugs.
toocaffeinated is offline
Old 10-31-2006   #2 (permalink)
Look into Rhinomotos. They are heavy and work well. Many styles available.-T1
have fun-ride often!
thruxtonone is offline
Old 10-31-2006   #3 (permalink)
Favorite Bike: The one I'm on!
Other Motorcycle: Red 2006 Sprint
Extra Motorcycle: Red/Black 2006 Bonnie
OK guys - I think I'm about to learn something new. The bar end weights - you said they stop or reduce vibration. Is this just for engine vibration, and if so, for the whole rpm range or only if you like to wind it out? This appears to be something that was not around when I had my last Triumph(35 years ago). :???:
I'm just browsing, thank you.
walt is offline
Old 10-31-2006   #4 (permalink)
Favorite Bike: 05 Bonneville T100 B/W
wenzel850's Avatar
Walt,
Go to maniacsalamander.com there is a complete explanation of bar end weights and how they work.
Quentin
"01-20-2009 I can't wait"
wenzel850 is offline
Old 10-31-2006   #5 (permalink)
I did look into the Rhinomotos and from my understanding they are light weight sliders. They do have an option for a steel/plastic combo but even those don't look as hefty as Manic Salamander's, which are about 13ounces on each side.
Old 10-31-2006   #6 (permalink)
Thanks wenzel850. Just did a quick checkout of the site during lunch - lots of possible new goodies. I knew getting back into biking was gonna be fun! :-D
walt is offline
Old 11-01-2006   #7 (permalink)
The Rhinomoto's that I purchased are stainless steel and have provision for CRG bar ends. They are heavy and did wipe out handlebar vibration.-T1
Old 11-01-2006   #8 (permalink)
Favorite Bike: '06 T100
Why not tap your bar plugs up from an M5 to an M6 thread and use the Manic's you want. Or else you can drill out the bulk of the plugs with a hole saw and clean up the rest with a die grinder and voila.
So long as you're not hopeing to go back to the stockers you'll be all set.
Some people are a lot like Slinkys.
Not really good for anything, but bring a smile to your face when you push them down the stairs.
Big_Rick is offline
Old 11-01-2006   #9 (permalink)
Right on Big Rick,
I heard from a couple of people who did just that, unfortunately the result wasn't much to look at. The fit is too awkward and people had to use washers etc to make the 6mm ends fit right. I also thought about drilling out the plugs and using the universal fit ends from MS, but I personally don't trust the expanding collet system to hold nearly a pound on each side. Its probably all in my head, but I would rather have the weights allen bolted to the bar. Also, this way we can use weights interchangeably between the factory bars and other that have the same ends.
Paul at MS being a nice guy doesn't mind putting the product out for us. I am sure he will design something great for us! Again if anyone is interested in them, email Paul and also if you have an unused set of end caps, please mail those to Paul.
[ This message was edited by: toocaffeinated on 2006-11-01 15:25 ]
Old 11-14-2006   #10 (permalink)
Here are some already available from Jenks.
Jenks Bar End Weights
Big_Rick is offline
Closed Thread
Bar ends..... Doc007 Speed Triple Forum 2 02-17-2007 09:07 PM
Manic Salamander Bar End Weights Ramjet Twins Technical Talk 2 09-01-2006 07:41 PM
Bar Ends VelvetHog Speed Triple Forum 16 08-28-2005 12:42 PM
bar ends chadoll Triumph SuperSports 7 06-29-2005 03:41 PM
