Nathan,
Yea, but that's not the typical C-130. And it's not the typical mission either.
I was just ribben you a little. After reading your comment i had a hunch and went to your profile. Sure enough 2+2=4
I know you are a slave to that thing and got to work your butt off to keep it fmc.
At least yours are designed to fly.
It was all I could to persuade mine to get off the ground. The thought of a 100hr phase maintence was enough to send me into a depression.
You know its bad when they start referring to it as the "hanger queen"
you might be stuck out there but look on the bright side. At least your getting some flight time without having to restock your flares.
Given the mission profile of that thing, I would think that you would be enjoying a slightly slower paced lifestyle. :razz:
Besides, I don't think they let you have POVs in a combat area. Even if it is a Triumph.
Take it as easy as you can.
Thanks for serving.
:razz:
