Hey Mantis - I experienced the same problem while replacing the springs and fluid on my 01 Bonnie. I was glad to see your posts on this.
One question - Is it just a matter of pulling hard enough and dislodging the stuck parts, such as if I put the tubes back in the triple tree clamps and used the axle to evenly pull on the tubes, or did you have to replace parts? Were there any damaged parts that had to be replaced?
Thanks
