Make sure the bulb connector is fitted back in properly. I did this to when I had to tighten my turn signals that the dealer left very very loose when fixing my flat.
Anyway, the bulb needs to go in a particular way. I blew 2 fuses before rechecking my handi work and noticed the little black plastic contact was not seated properly back into the hole. Mine has a sort of key fit to it. Then I put the ***** bulb in wrong. running light was very bright and brake was very very non-noticable. reversed it and working fine now.
The key is that contact point. Make sure it is seated properly. I had mine kind of jammed in there and it was shorting out.
Hope this helps, and pertains to your issue. I am after all a newb here still.
