BikeBanditAdvanstarMotorcycleShowsMotorcycle.com
Closed Thread
Old 09-22-2006   #1 (permalink)
When I first bought my Bonneville T100 I had the dealer install chrome headlight brackets. Now I'd like to put back the original black brackets however I don't know to do this.
How difficult would this be to do?
Does anyone have any instructions or advice?
Better yet does anyone have a pdf file or know where I can look up info on this?
brownbomber is offline
Old 09-22-2006   #2 (permalink)
Retired Legend
sweatmachine's Avatar
You can go in from the top or bottom, do you have a bike jack?
If you take the top clamp off you'll have to remove or cover the gas tank to protect it from dents or scratches. You'll have to take the headlight off, 2 bolts on each side and let it dangle by the wires.
You will probably have to open up the headlight and disconnect the turn signals in order to remove them from the brackets. It's a mess in there, but there's nothing to be afraid of. To see pictures look at my post HERE
Once the top clamp is off you can slide the brackets off the top of the fork legs, after you've disconnected the turn signals and removed the ignition.
It's all really straighforward, no suprises. I did mine by taking the fork legs out the bottom, I think it's about the same work either way, but you can do it one leg at a time which I think would be easier.
For that, you'd remove the front wheel, unhook the brake caliper from the left leg, and the speedo cable, then remove the front fender, and loosen the bolts on the triple clams, see also Keef's wonderful post on fork boot installation here
basically it boils down to taking it all apart...it really helps to have a proper motorcycle jack.
sweatmachine is offline
Old 09-22-2006   #3 (permalink)
thanks sweatmachine. yep, i have a jack and i'll probably have to take before and after pics so that i remember where everything goes.
sweatmachine i read your posts about your headlight project and was very impressed with the results.
Old 09-22-2006   #4 (permalink)
Retired Legend
hey thanks.
I think you may be able to unplug the turn signals from the connectors, but you may have to solder the connections. I used aftermarket turnsignals when I put it back together so I soldered them.
Drop a line if you have any questions while doing it, as it's fresh in my mind...
Old 09-22-2006   #5 (permalink)
Favorite Bike: My 904 Bonnie
keef's Avatar
Extra Motorcycle: dya mean the one outside?
.... see also Keef's wonderful post on fork boot installation here.
Thanks sweat, you do me such a credit! :wink:
Rides:
2001 Bonnie: Mods - Wiseco 904; KARK; Togas; Hagon Nitros & Progressives, etc.
The Wife: Mods - haircut; earrings; children
keef is offline
Old 09-24-2006   #6 (permalink)
5bassman's Avatar
Are you interested in selling the chrome ones? If so email me at jsfricks@yahoo.com
2005 Triumph Bonneville Black
5bassman is offline
Closed Thread
LSL Headlight Bracket Broms Twins Technical Talk 2 12-04-2007 06:08 PM
Holes left by removing front fender bracket? TommyTwin Twins Technical Talk 6 07-17-2007 08:47 PM
Headlight bracket TCL Twins Technical Talk 5 04-07-2007 01:15 PM
Headlight Bracket Whitehurst Club Cafe 24 02-01-2007 12:58 AM
Headlight Bracket Replacement jquattro Twins Technical Talk 2 12-29-2006 05:46 PM
