Since it was supposed to rain all weekend, and I had nothing better to do with my time than spend it sweating and swearing in the garage, I thought I'd address a little problem that has been bothering me about our beloved bonnies.
If you look at the bikes from the side, there's a nice line from the tank to the seat, but the headlight is too high and it makes the front forks look really long. Keep in mind this is only the opinion of a madman with more time on his hands than good sense.
exhibit A:
I have already installed a shorter rear fender, but it's going away too for something more radical (and tubular).
So here are the phase 1 photos...
you gotta take it apart, right?
I also wanted to paint my headlight bucket black. LOOK HOW MUCH JUNK IS INSIDE THE HEADLIGHT!!! It looks like Radio Shack puked inside it!
I thought that maybe I could swap the headlight brackets left to right and it would lower it a little, WRONG! They would be the exact same, except you could do this to switch the key over to the other side.
Here are stock brackets:
And here are mine after I cut an inch and a half off the bottom side and welded it to the top to lower the light:
I'm not the best welder, and even the best would have a hard time with these because they're super thin stamped steel, so here's the bondo:
I wanted to mount the gauges below the top triple clamp, as Mancha had suggested and some of the Thruxton guys have done, but the Bonnie top clamp is different and it cannot be done as easily...you could do it, but it wouldn't lower it very much. I ran to Home Depot and bought all kinds of hardware, spacers, bolts, etc, and then I noticed the 2 bolts that hold the wire bracket thingy in place, they're torx fasteners (why?) and are upside down, just in front of the handlebar riser clamp underneath. These are very substantial so I made a bracket out of some 1/8'' plate I had laying around to bolt the gauges to them.
making the paper template for the bracket:
The rough bracket, hand cut with an angle grinder, a drill press, and a lot of filing and grinding:
Here's the raw bracket test fitted to the gauge cluster:
and here it is fitted to the gauges and bolted to the top triple clamp. Note the Torx fasteners, the wire loom was left out in this pic, but reattached later!
Once installed it is all but impossible to see, but I didn't want it rusting on me, so here it is after cleaning it up and hitting it with the Rustoleum:
Priming the bondo'd and sanded headlight brackets:
COmign up next! Paulie and Sr clash as deadlines loom and tempers rise...oh wait different show...
Anyway, reassembly commences tomorrow, I'm waiting on paint to dry in my oven/garage (102 today with the heat index, doesn't help a hangover at all).
I test fit everything and it looks very cool. More pictures to follow...I'm also installing new turn signals and a new taillight...STAY TUNED!
