Closed Thread
Old 08-24-2006   #1 (permalink)
Has anybody attempted to remove the evaporative loss system off their bonnie or scrambler? Are there any good online tutorials for the surgery?
Seems like a ton of hoses involved in the apparatus, and in the name of eliminating any possible sources of vacuum leaks and keeping the engine uncluttered I'd like to get rid of the thing. I'm not sure, but I think it may only be on California bikes.
Any pointers would be much appreciated.
Thanks,
Jonah
JonahP is offline
Old 08-24-2006   #2 (permalink)
Theres a PDF file in the downloads section on how to do it. I had questions after reading it, but others have used it just fine. And it IS only Ca that has it.
Here it is
[ This message was edited by: dazco on 2006-08-24 21:06 ]
dazco is offline
Old 08-24-2006   #3 (permalink)
Isn't a evap loss system just a charcoal cannister on the tank? Or are the carb vents included too?
If it's just the tank, you aren't gonna cause any vaccuum leaks that way.
2006 Thruxton
monkeyboy is offline
Old 08-24-2006   #4 (permalink)
No, it's a 2 cannisters and some valves and a ton of tubing hooked up to the carbs and the tank. It's pretty substantial, not just a simple cannister. Look in the manual and you'll see it.
dazco is offline
Old 08-25-2006   #5 (permalink)
I removed it from mine using the instructions in the link in Dazcos post. It was pretty easy, took maybe half an hour. It really cleaned up the engine area, and like you said there is now less things to go wrong with the bike....I heartily recommend it! Been running without it for about 15,000 miles now..No problems.
My Baby
Copper is offline
Old 08-25-2006   #6 (permalink)
When I remove it, will I have to adjust the carbs at all or will the mixture, etc.. remain the same?
JonahP is offline
Old 08-25-2006   #7 (permalink)
no
dazco is offline
Old 08-25-2006   #8 (permalink)
Jonah, no adjustments needed, the system has no noticable impact on the engine (unless it develops a vacuum leak!)....Just pull it off and away you go....
My Baby
Copper is offline
Old 08-26-2006   #9 (permalink)
WE DONT HAVETHEM HERE (YET). WE ALL WILL SOON THO. I THINK YOU JUST REMOVE IT & HAVE ATUBE HANGING DOWN AS DO THE NON-REQUIRED ONES? AHHHH TO LIVE IN CAL OR NJ? NEVER AGAIN!!
CAPT D
CAPTDON is online now
Old 08-27-2006   #10 (permalink)
Thanks for the instructions and advice. Removed it tonight and can't believe how much better the bike looks.
2lbs of junk.
JonahP is offline
Closed Thread
Evaporative canister milqster Speed Triple Forum 6 11-26-2006 11:16 PM
2000 885fi evaporative loss system glgavin Tiger Workshop 6 09-20-2006 12:13 AM
Help! evaporative loss system Colonel_Dorkus Twins Technical Talk 1 09-09-2006 07:50 PM
Evaporative Loss System - in England! TonyD Hinckley Classic Triples 0 08-23-2006 05:23 PM
A I/evaporative loss system on '05 speed triple? Big_Guns Modifications & Workshop Talk 5 01-10-2006 07:04 PM
