Closed Thread
Old 08-21-2006   #1 (permalink)
Retired Legend
sweatmachine's Avatar
I'm interested in drilling the slide out to 3mm, can someone tell me how to do it?
Do you pull the diaphragm assembly out through the top of the carb along with the slide?
thanks
sweatmachine is offline
Old 08-21-2006   #2 (permalink)
Retired Legend
I didn't mean to put the frowny face on that last post...
Old 08-21-2006   #3 (permalink)
thanks
Yep, that's it. I used a 7/64 in drill and ran it thru a couple of times. I couldn't find a 3 mm drill bit.
TTBONNE is offline
Old 08-21-2006   #4 (permalink)
http://www.frontiernet.net/~dmclec/slide.html
Sweatmachine, try that link up above, from a guy on BA with a handle of Triumphant.
Michael D. Rodriguez
RoundSlide is offline
Old 08-21-2006   #5 (permalink)
Yep!
The hole is on the bottom corner of the slide, metric drill bits are hard to find a 7/64 is close to 3mm on the small side... You can also match balance the weight of the slides so they weigh the same.. To do this you can remove material from where the spring goes in on the top of the slide, using a dremel with a sanding drum.. It does not take much to get them perfect...
1409 is offline
Old 08-21-2006   #6 (permalink)
Retired Legend
I think I read someone write that it was a huge pain to get the diaphragms back in there, what's the trick to that? patience?
Old 08-21-2006   #7 (permalink)
Favorite Bike: '06 Bonneville Black
Other Motorcycle: '89 FXR
For All Your Engine Needs
Hated By All....cause thats just how it is.
SCCTrim is offline
Old 08-21-2006   #8 (permalink)
Retired Legend
Hey Roundslide, thanks for the link!
Old 08-21-2006   #9 (permalink)
No worries
Old 08-21-2006   #10 (permalink)
Before you go doing this realize the in 05 they widened the slides so you don't need to. I know they did on the cruisers and the bonnies too i'm sure because i believe they use the same carbs. I'm not sure of all the details and how wide they made them on the last 2 year models or whether going higher than they are now will be detremental. But you should find out before wasting your time. I know there are people at BA that know about this so they can probably give you some of the answers.
dazco is offline
Closed Thread
Drilling the slide????? bung1 Modifications & Workshop Talk 9 09-01-2007 09:03 PM
Slide drilling negatives AVMECH Club Cafe 5 03-26-2007 04:09 PM
Slide drilling negatives AVMECH Twins Technical Talk 14 03-25-2007 12:15 PM
Thunder Slide , Lightweight Slide ?? FEDCT Club Cafe 0 05-26-2006 08:46 AM
Carb slide balance drilling? sailfish T3 Sport / Touring Forum 25 03-03-2005 11:11 PM
