You may be in luck..... or not. Depends on who you talk to. If you don't butcher your tire as I have pictured below, there are some super duper high tech swoopy doopy plug/combination/patches that are used on truck and/or automotive tires. You gotta take your tire off your wheel, but it's supposed to be a pretty safe bet for a decent repair.
On the other hand, what I have used on a dozen motorcycle tires and two car tires, is the below pictured "Tire Plugger" kit. It uses a mushroom type plug, and when properly installed..... doesn't leak. There must be NO cord/cable running through the tire anywhere near the plug, or it may slice the plug (the old style cord plug seems to resist the slicing better).
Now.... I put a significant amount of miles on a couple of these plugs installed in motorcycle tires, but it's not a good practice to risk one of your narrow footprints that help stick ya to the tarmac. That is to say, it is ill-advised to run on a plugged tire any more than it takes to get home....
But I also put thousands upon thousands of miles of high speed snot-nose driving like a teenager, on a plugged tire on my Mazda..... but I had three other footprints with a car....
Sooo...... if the plug is center-tire, and it's not installed in the middle of a tread groove, and you have plenty of life/tread left in the tire, and you watch your speed, and you never say I said so..... well, the risk is a good one, for maybe a weekend.... or maybe not.
Go to a bike shop and look for either the "Pocket Plugger" or a "Tire Plugger" kit, it's VERY handy if you get a puncture and you're miles away from home.
