Trident-Exhausts.comAdvanstarMotorcycleShowsBikeBandit
BikeBandit
Closed Thread
Old 06-20-2006   #1 (permalink)
Tired of searching around for that transmitter to open or close your garage door when leaving or approaching your house, or worse yet, having to get off your bike to use the control panel on the door itself? If so, I found a neat little goodie to add to your Bonny. Check this out:
Autoswitch Garage Door Opener
I’ve been using this autoswitch (positive voltage version) for about a week now and it’s worked great so far. You install it on your bike along with an extra garage door opener transmitter that you can dedicate to this purpose. The autoswitch has 5 wires you need to hook up: two get soldered to the button contacts on your garage door opener transmitter board, one goes to ground, one gets tapped to a switched 12V power source, and one gets tapped to the source of the signal you send to activate the transmitter. I accessed a switched 12-V power source right under the fuse box (I picked the horn wire to tap into). For the “signal source”, I used my rear brake light. You can find this wire right next to the rear brake master cylinder (the green & purple wire). Installed in this way, all it takes is a quick double-tap on the rear brake pedal to actuate the garage door opener! (Make sure you’re not using your front brake at the same time though, or it won’t work.) There are other ways you can connect this neat little device up too. However, I found that the approach above gave a nice compact install on a Bonny. All the wires can be collected to the right side of the battery and packaged real neatly, along with the garage door opener transmitter and autoswitch under the right side panel.
[ This message was edited by: SweetWilliam on 2006-06-20 00:08 ]
-Chuck
SweetWilliam is offline
Old 06-20-2006   #2 (permalink)
Favorite Bike: Triumph
bluesjeans's Avatar
plus a couple more garage door openers..
http://www.motofx.com/
(write-up on the motofx-->) http://www.webbikeworld.com/t2/motofx/
http://www.mcgdo.com/
[ This message was edited by: bluesjeans on 2006-06-20 00:04 ]
bluesjeans is offline
Old 06-20-2006   #3 (permalink)
Other Motorcycle: 66 Bonnie Chop
Chuck:
That version you used is much less than the MotoFX piece, good find. I basically did the same thing but just wired a momentary switch to a mini-garage remote from Lowe's (Genie, $30). You run a two-wire lead from the remote to the momentary switch. I covered the remote in plastic and it's stored above my battery, under the seat. Way convenient!
Al
ssjones is offline
Closed Thread
Beer opener mglemans86 Biker Hang-Out 7 12-07-2007 10:10 AM
DIY integrated garage door opener CLB Sprint Forum 2 07-01-2006 07:50 PM
Garage Door Remote Button Mod Ridge Modifications & Workshop Talk 4 06-21-2006 10:09 PM
Garage door openers? Geof3 Speed Triple Forum 10 10-06-2005 10:10 AM
Garage door opener installed on bonnie Ubergiles Twins Talk 25 08-14-2005 03:44 PM
