Closed Thread
Old 06-19-2006   #1 (permalink)
I can't get mine to thread in! It won't even start. Just kinda sits on top of the opening and allows one turn.
Gaskets aren't the issue here, the ***** thing just won't fit to screw in.
I used search to see if anyone else had this problem and the one I found had no answer...
Anyone else have this issue?
http://www.newspeedmaster.com/html/f...t_gas_cap.html
[ This message was edited by: tartan on 2006-06-19 17:36 ]
tartan is offline
Old 06-19-2006   #2 (permalink)
Favorite Bike: 04 America. Black, chrome, with a hint of red for contrast.
tba-golfer's Avatar
Um, don't know what to tell you...
You're sure you've got the gasket scenario correct?
What's your ride?
When in doubt, call Brent- he'll help, replace, whatever.
I have been really pleased with mine.
No problemos.
What's the most amazing thing you've ever found?
Impossible to say. You see there's something amazing every two or three weeks.
Local Hero (1983)
tba-golfer is offline
Old 06-19-2006   #3 (permalink)
'06 Speedmaster
Gaskets aren't the problem at all. It just won't start to screw in...even had a neighbor with mechanic skills try it in case I was missing something. Neither of us could get it to fit.
Guess I'll give 'em a call tomorrow and see what's up, if anything...
tartan is offline
Old 06-19-2006   #4 (permalink)
tba-golfer's Avatar
Good idea- Brent will be straight with you.
Maybe even more mints!
Or, is that your game...?
:-D
Local Hero (1983)
Old 06-19-2006   #5 (permalink)
Favorite Bike: 05 Black Speedmaster
Have a look at the threads on the insert as the machining is done in haste. Remove the burr and it will thread fine.
Normandy is offline
Old 06-19-2006   #6 (permalink)
I'm having the same problem.
Normandy, what is the "BUR"?
Trump is offline
Old 06-19-2006   #7 (permalink)
Hope you don't mind my speaking up, but a burr is a defect on a thread that looks like semi-attached excess metal, and in this case getting in the way of a clean start to the mating threads. You might try a careful hand with a small jeweler's file to chase the threads and get rid of the offending burr. Use a loupe or a magnifying lens to get a better view of the action. You don't want to replace one problem with another.
Raven is offline
Old 06-20-2006   #8 (permalink)
Thank you
Normandy is offline
Old 06-20-2006   #9 (permalink)
Had the same problem when I first went to put mine on last year. It starts hard but once you get it going it goes on fine.
It may likely have some type of imperfection in the thread which a little quick filing should fix.
If you choose not to decide, you still have made a choice.
stdbkrhwk is offline
Old 06-20-2006   #10 (permalink)
I installed that cap a few months ago. I do recall it is a bear the get started. I used the 2 brass bolts, with a pry bar inbetween them, (a small prybar), and smeared neversieze on the tank threads. Its a really tight fit so it will not turn out when you take out the little cap to fill her up.
HOG= Harley OWNER group
RAT= RIDER Association of Triumph
Matt_the_Rat is offline
Closed Thread
Flush Gas Cap Jhtjon Twins Technical Talk 5 08-17-2007 10:48 AM
Flush fit gas cap 127mph Club Cafe 3 07-05-2006 11:23 AM
Gas cap is like child proof medicine cap and I'm kid rays323929 Twins Talk 14 05-14-2006 10:52 PM
Flush Mount Gas Cap from Newspeedmaster.com Speedster800 Twins Talk 1 01-16-2006 01:14 PM
Flush mount gas Cap from newspeedmaster.com Speedster800 Modifications & Workshop Talk 0 01-16-2006 11:37 AM
