Take off the cam cover and apply a little "Three Bond Liquid Gasket 1104" to the seal and your leak should be history. Also, the proper way to remove the cam cover is to use a rubber mallet to get it loose--no prying under the cam cover--the o-ring type gasket can be damaged easily...the dealer's mechanic used a screw-driver on mine at the 12K valve adjust maintenance and I had a leak on both sides. A little Three Bond and no more leak...even though the gasket was damaged badly on one side. Why would a "mechanic" put it back together with a damaged gasket??? Surely, they would have one in stock in the parts dept.
Larry
Larry
