BikeBandit
Closed Thread
Old 06-17-2006   #1 (permalink)
On my 05 T100 my left header is blue and my rt header is gold (oriented sitting on bike) Bike has 750 miles, Toga pipes and rejet and AI out. Bike runs absolutely beautiful. I love the blue pipes, will the other one catch up.?? Carbs are balanced as tech said at 500 mile service. Best bike I have ever run, very smooth. Thanks for any help.
pupkin is offline
Old 06-17-2006   #2 (permalink)
Right on schedule. My right is catching up at 8000 miles.
05 Thruxton
whoa is offline
Old 06-17-2006   #3 (permalink)
mecscc's Avatar
It will take longer with the AI removed, but eventually. Look at it this way, its hard to look at both pipes at the same time so nobody else will notice. :-D
Monte
Monte
"The Old Ohio Preacher Man"
mecscc is offline
Old 06-17-2006   #4 (permalink)
petemw's Avatar
I was just looking at mine the other day wondering why the right was a little lighter than the left...At least now I know that I'm not the only one.
And now to go out for a beautiful ride with the Parabellum off...It's too hot!
Cruise'n the free world
petemw is offline
Old 06-17-2006   #5 (permalink)
Favorite Bike: 904 Bonnie/Daytona 675
Brooksie's Avatar
Either a sync problem or left to idle on the side stand too long.
Brooksie is offline
Old 06-17-2006   #6 (permalink)
Favorite Bike: 2006 Triumph Bonneville T100
Scrambler900's Avatar
Other Motorcycle: 2006 Triumph Scrambler
My Scrambler with 400 miles on the odometer has the exact exhaust coloration as you described - slightly blue onthe left and golden on the right.
[ This message was edited by: Scrambler900 on 2006-06-17 18:46 ]
Stay cool, like Steve McQueen
Scrambler900 is offline
Old 06-17-2006   #7 (permalink)
I hear in Australia it goes the other way, blue on right, gold on left. :-D
05 Thruxton
whoa is offline
Old 06-17-2006   #8 (permalink)
Scot03Bonnie's Avatar
That happens because of the way the Bonnie ignition is set up. The coil fires both plugs at the same time on each crank revolution, and because of that, one plug lead gets a bit more energy from the coil and thus runs very slightly hotter than the other. If you swap the plug leads, the gold header will catch up to the other one. Don't worry it will run just fine. I did this after buffing the blue off my headers, which was after dialing in the jetting. Sure enough one got a little gold and the other got no color. I swapped the leads and the other pipe turned gold within a day.
I've since replaced my stock coil with a Nology from New Bonneville, along with the Nology grounded plug wires. No spark imbalance now.
Cheers!
Scott
Scott- ATL
Scot03Bonnie is offline
Closed Thread
crap! hit left header pipe, where to get replacement? jeffz Twins Technical Talk 16 12-19-2007 01:16 PM
Flack damage on left header pipe n578md Twins Technical Talk 4 10-15-2007 04:15 PM
Header bolt torque / Connecting exhaust to header whodkne Speed Triple Forum 3 04-11-2007 11:44 AM
Left hand header turning blue and engine pinks CaptRussell Classic, Vintage & Veteran 6 10-18-2006 01:49 PM
Blue header pipe womcat Sprint Forum 0 05-30-2006 08:46 PM
