What is the snorkel? - Triumph Forum: Triumph Rat Motorcycle Forums
Closed Thread
Old 06-12-2006, 05:39 AM   #1 (permalink)
Could someone please explain, what is the snorkel (on a Bonneville)?
Cheers
Torro is offline
Old 06-12-2006, 06:07 AM   #2 (permalink)
ozbon's Avatar
Location: Toowoomba Queensland Australia (soggy bottom)
It's the rubber air-intake, for a better word, that is located under the left hand side cover which directs air flow into your air box it can be pulled straight out and is "L" shaped.
john
"Yeah, look.....Baz just vanished, like a.....fart in a fan factory, ya`know?! ".
Daz, the cane toad.
ozbon is online now
Old 06-12-2006, 06:10 AM   #3 (permalink)
It's under the left side cover and acts as an easy access port for air intake but it is believed to actually restrict airflow a bit so a lot of us take it out....this is what it looks like when it's removed......
You can just yank it out by hand......you can put it back in if you want as well.
Not to be confused with the "Snorks" keep in mind...
Thunder_Forever is offline
Old 06-12-2006, 06:43 AM   #4 (permalink)
I have an 05 T100. I like the idea of improving air flow both in and out of the engine. I have Togas w/o the baffles and the bike has been rejetted for them.
If removing the snorkle increases air flow would I need to rejet? It seems to me that an increase of air into the engine generally necessitates rejetting. Is there an increase in noise associated with the removal of the snorkle? And where in the RPM range might I see a slight power increase (decrease???).
Are there any downsides like rain water getting in?
Thanks
CC
PA-guy is offline
Old 06-12-2006, 06:44 AM   #5 (permalink)
Does anyone have data that removing the snorkel on a T100 actually helps with an increase in power?
TTBONNE is offline
Old 06-12-2006, 06:56 AM   #6 (permalink)
Removing them on my TBA lets water into the air box when I was the bike. I don't really think they are all that much of a problem.
My plan is to install K&N's in both of my TBA's when extra cheese permits. That should help with airflow.
Brit26
Brit26 is offline
Old 06-12-2006, 07:00 AM   #7 (permalink)
Thanks
CC
You know, I wondered about the re-jet too but the issue never came up and my bike has ran great all 20k miles *knock on wood*
I pulled mine right at the same time I put on my D&D pipes (like I said, no re-jet either....didn't need it) So there was no way of telling whether the snorkel had any effect on the power itself because I had a noticable increase from the pipes....no water gets in there and I've ridden in some pretty heavy rain out here.....My goggles turn into fish tanks over my eyes and the bike is fine...
Old 06-12-2006, 12:27 PM   #8 (permalink)
So you can actually just remove it without doing ANYTHING else?
Torro is offline
Old 06-12-2006, 12:34 PM   #9 (permalink)
Favourite Bike: '64 Norton N15CS
McQueen's Avatar
Other Motorcycle: '79 Triumph T140D Bonnie
Extra Motorcycle: '71 Triumph T100R Daytona
You bet. Just take off the left side cover, grab the snorkel, and pinch-wiggle it out.
I yanked mine out (and added a K&N filter) and didn't need to rejet...
+ Ton Up Club NorCal +
Nothing says "it's my first day on the Internet!" like putting a picture in your signature.
McQueen is offline
Old 06-12-2006, 12:37 PM   #10 (permalink)
Favourite Bike: My old Bonnie
doctorjay's Avatar
Other Motorcycle: Triumph Thunderbird SE
I have a stock T100. If all this stuff needs to come off or be changed, wht can't Triumph offer that to begin with. My mufflers are OK with me. I have all the stock AI, filters, etc and I have PLENTY of get up and go. Please explain why I should pay close to 1000$ for all this "upgrading" :???:
Thriumph Thunderbird SE 2010
doctorjay is offline
Closed Thread
Snorkel? Kramocker Twins Technical Talk 7 09-17-2007 03:18 PM
snorkel wildchild Twins Technical Talk 7 04-30-2007 02:06 AM
Snorkel ? 2Marks Twins Technical Talk 1 11-25-2006 01:01 PM
What is a snorkel?? lbo Twins Talk 19 09-17-2005 11:15 PM
snorkel in or out? mrgadget Twins Talk 7 06-20-2005 03:34 PM
