TBA oil? I'm leaking...a little.... - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comMotorcycle.com Classifieds!Ontario Tourism
Closed Thread
Old 06-11-2006, 07:44 PM   #1 (permalink)
Am curious if this is REALLY abnormal or if I'm getting a bit worried over nothing that's a huge ordeal.
The connection to the clutch cable on the engine on the left side of the bike appears to be releasing oil. It's not a lot and it's almost as though the wind drives the oil out. At lower speeds 45mph or under I can virtually ride and not see anything coming up from this area. At 55-70+mph it starts to run out a bit more.
Another thing I noticed is that it almost appears as though there should be a rubber gasket there where the clutch pin coming out from the engine is so as to not release oil.?. Any ideas what this could be? Am I missing a gasket and just don't know it?
Thanks for any input on this.
~Joe
code is offline
Old 06-11-2006, 09:49 PM   #2 (permalink)
Favourite Bike: '03 T-100 & '08Tiger1050
1. No oil leaks is NORMAL for these new bonnevilles.
2. Oil leaks are abnormal and should be fixed, IMHO.
3. There is a bearing and seal in the case cover for the clutch release arm. If yours for sure is leaking at this place, I would suspect a damaged clutch release arm seal.
Larry
Larry
RedBird is offline
Closed Thread
Leaking Oil Linz Daytona Deliberations 3 07-04-2007 01:04 AM
Leaking Oil qc415 Speed Triple Forum 3 09-23-2005 07:07 AM
Oil leaking ??? ww Tiger Chat 5 08-17-2005 02:03 PM
Leaking Oil... MeshMan Triumph SuperSports 1 06-29-2005 01:21 AM
Not sure But could I have oil leaking somewhere? Mutley Tiger Chat 5 05-17-2004 09:44 AM
